Author Topic: Strange Build Date 10 V  (Read 914 times)
Offline D0ZZ70MACH
  • 1970 Mach 1 Dearborn 11/10/1969
« on: May 14, 2024, 09:20:47 PM »
Hello all.
Here's one that I've not seen before but hopefully someone else has an answer. The build date on the door data plate of this Dearborn built 1966 A code is 10V. Since Ford used A-M for the month codes, could this simply be mis-stamped by the factory? I won't have access to the car until Thursday to confirm the build date / date stamps of various components on the car.
Thanks for the help!!!
Re: Strange Build Date 10 V
« Reply #1 on: May 14, 2024, 10:25:55 PM »
Totally legit for Dearborn. August 10, 1966.
Offline D0ZZ70MACH
« Reply #2 on: May 15, 2024, 05:53:30 AM »
Thank you for the confirmation.
In that case a very late build. I believe the last day of Mustang production at Dearborn was 8/12/1966.
« Reply #3 on: May 15, 2024, 07:53:47 PM »
Of course the 10V was the date guesstimated back when the order came in and the Aug 12th would have been a date arrived at from different sources and reasons  :)
As we know and accept the date stamped on the door/warranty tag is often not the build date, the date the car was completed or even started on.
