Author Topic: '65 K code lower clutch spring  (Read 1198 times)
Offline C5ZZKGT
  • Gold Level Subscriber
« on: May 20, 2011, 06:08:42 PM »
Mine rubs aganst the exhaust manifold and makes noise whenever I push in or let out the clutch, it seems to be installed right/the way I remember it being......any ideas or is it just the fact of the Hipo manifolds?
Re: '65 K code lower clutch spring
« Reply #1 on: May 23, 2011, 10:36:29 AM »
Probably going to have to provide a pic.  Does your bell housing fork lever have a point on the exposed end or is it flat?
Offline MWM
« Reply #2 on: May 23, 2011, 06:24:00 PM »
I had the same issue.  My solution was to drill a small hole in the under engine cross brace and move it over about an inch.  Good Luck!
