Author Topic: Holes in dash  (Read 1489 times)
Offline birddog
Holes in dash
« on: April 29, 2024, 03:36:18 PM »
I'm trying to do the final welding on the dash. Curious if anyone has pictures of an original dash, especially underneath. The first picture is the possible location of GT fog lights switch. Does that location and size of the hole look correct? I would also like to weld all other holes under the dash. Some are pretty obvious that they were added at a later point. Others I can't tell for sure. Thanks. BTW the car is upside down on a rotisserie.
« Last Edit: April 29, 2024, 03:38:27 PM by birddog »
Re: Holes in dash
« Reply #1 on: April 29, 2024, 03:50:20 PM »
The holes in the bottom of the dash are pretty typical. Some are factory while most are added by prior owners when they attached gauges, 8 tracks and such to modify they cars.
We'll see if we can post some unaltered examples to help but you can help out providing when and where your car was built
Re: Holes in dash
« Reply #2 on: April 29, 2024, 04:03:52 PM »
The 1965 and 66 Fog Lamp switch is not under the dash but located on the "slope" about halfway up between the lower bend and the edge of the instrument panel. I'll try to get a picture and dimensions later.
It would be advantageous to you in your questions and other members in answers if you included the year, plant, model and scheduled build date in your posts.
If you do not have a set of Mustang Assembly manuals for your car's year, I urge you to get a set. I've got my right elbow resting on the 65 Mustang Electrical Manual page with the fog lamp wiring.
Offline birddog
Re: Holes in dash
« Reply #3 on: April 29, 2024, 04:49:36 PM »
Thanks. It's an early 1965 Fastback San Jose build. It's a non GT, but I may add the GT fog lights.
Re: Holes in dash
« Reply #4 on: April 29, 2024, 05:26:05 PM »
Rough location for the fog lamp switch hole is 1 1/4 inches from the left hand edge of the dash and 4 inches up from the bottom edge. The picture is from a 66 GT Fastback built in San Jose on 18 Oct 65. My 65 GT Fastback has a similar location.
You "may" get dimensional instructions from a fog lamp kit.
Oops. Wrong picture the first time. The correct picture is there now.
Re: Holes in dash
« Reply #5 on: April 29, 2024, 11:34:09 PM »
Here are some pictures of the bottom of the dash - Hope thy help
#1
#2
#3
#4
#5
#6
#7
#8
Re: Holes in dash
« Reply #6 on: April 30, 2024, 01:19:39 AM »
The original question was where to mount the fog lamp switch on a 65 Mustang. To date, that switch was not factory mounded on the bottom of the dash.
« Last Edit: April 30, 2024, 03:17:13 AM by J_Speegle »
Re: Holes in dash
« Reply #7 on: April 30, 2024, 03:18:31 AM »
As I read the post the GT light switch was one (the first) of two requests \
OP  wrote - "I would also like to weld all other holes under the dash. Some are pretty obvious that they were added at a later point. Others I can't tell for sure."   ;)
Re: Holes in dash
« Reply #8 on: April 30, 2024, 11:41:22 AM »
It's my one track mind in action.  8)
Offline birddog
Re: Holes in dash
« Reply #9 on: April 30, 2024, 10:20:02 PM »
Thanks guys! I'm going to start welding up some holes.
Re: Holes in dash
« Reply #10 on: May 01, 2024, 06:18:01 PM »
Depending on how good a welder you are, consider using "JB Weld" on the smaller holes. I also used Bondo on my dash installing a "radio repair panel". My "welds" of the panel warped the dash.
Re: Holes in dash
« Reply #11 on: May 03, 2024, 06:08:00 PM »
Hammer them flat since they often are irregular from tightening the screw or drill bit into the hole when made
Get a cooper plate to hold on the back side and it should go well
Offline birddog
Re: Holes in dash
« Reply #12 on: May 05, 2024, 08:37:48 PM »
I got some dash holes welded. The first picture is directly under the ignition switch. Going off J-speegle pictures. The green circle is an under dash light. The red is not used. The other two look like clean holes. Are these factory or add on?s
The second picture is directly under the glovebox. The green circle is obviously factory. The next hole closest looks like maybe a factory hole. A little worn out. And the furthest red circle is the same size as the first but more worn and maybe rusted out. Are the red circles factory? Thanks.
