Author Topic: Heater Hose clamp or bracket  (Read 725 times)
Offline lmennis
« on: April 15, 2024, 07:25:08 PM »
I have a 1969 with a 302 engine. The car did not come with A/C. There are two heater hoses which need to be properly clamped down/attached. At the moment they are not attached to anything in the engine compartment and basically are sitting on the valve covers. I see there are two holes on the firewall where it appears a bracket or clamp holds them in place. However, I can't seem to find specifically what the item is that holds these two hoses in place. Are they two separate pieces or one piece for both hoses? When I look online I see clamps for other years but I want to have what is correct for this car. I want to properly attach these hoses to the firewall or shock tower where they are supposed to be. Any help or a part number is appreciated.
Re: Heater Hose clamp or bracket
« Reply #1 on: April 15, 2024, 08:01:12 PM »
The hoses are not "attached" but "routed" per the 1969 Mustang Electrical Assembly Manual (AM0028) pg 42. I recommend you get a set of the manuals.
Offline lmennis
« Reply #2 on: April 15, 2024, 10:01:16 PM »
I will get the manual but I am wondering what those holes on the firewall are for?
« Reply #3 on: April 15, 2024, 10:04:41 PM »
One could be for the engine block (back of the head) to firewall ground. Also you have larger holes for the rubber plugs holding the firewall pad on.  That is in the electrical manual . https://www.npdlink.com/product/assembly-manual-1969-complete/217284 . It is all covered in the manuals.
« Reply #4 on: April 15, 2024, 11:07:14 PM »
I have a 1969 with a 302 engine. The car did not come with A/C. There are two heater hoses which need to be properly clamped down/attached. At the moment they are not attached to anything in the engine compartment and basically are sitting on the valve covers. ..............
The two hoses pass through the firewall and attach to the non-AC heater box/heater core at the nipples. No bracket to hold them and clamps only in the interior - not visible from engine compartment on a non AC car
Different year but same design and route
The other ends attach to the nipple on top of the intake (front) and the other to the second water pump nipple at the front of the engine
There is a whole handful of pictures of the engine compartments in the Unrestored 69 Mustang section. In some cases (common after all these years) the hoses and clamps have been replaced but will at least, in those examples, show you where they attach. Any of the non AC small blocks should help
If your going for the original look you'll need tower clamps at both ends. Ford part numbers will do you little good but undated reproductions are available
