Author Topic: What is the difference between 69 and 70 R code air cleaners?  (Read 3208 times)
Offline DaveF
I have a 70 R code 428 SCJ. Someone told me that the air cleaner, or part of the air cleaner was for a ?69. I really can?t see the difference. Anyone?
« Last Edit: April 11, 2024, 12:45:01 AM by DaveF »
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Offline P3sons
Re: What is the difference between 69 and 70 R code air cleaners?
« Reply #1 on: April 11, 2024, 11:33:11 AM »
There is a slight difference in the bases between 1969 vs. 1970.
I believe the 90 degree elbow is metal in 1969, and plastic in 1970.
Paul Steinborn  Classic Automotive Ltd
1965 GT convertible K code San Jose 5R08K202XXX  3/26/65
1971 Boss 351  Dearborn  1F02R214XXX    6/9/71
1969 Mach 1  R code  Metuchen 9T02R175XXX  2/24/69
Offline JohnB
  • 0F03R120303
« Reply #2 on: April 11, 2024, 12:19:42 PM »
https://www.428cobrajet.org/id-main
« Reply #3 on: April 11, 2024, 02:47:07 PM »
Just guessing but since someone suggested you have a 69 style you might have an early style (for 69) without the vent in the base.
Offline DaveF
« Reply #4 on: April 12, 2024, 04:20:39 PM »
Actually, my car was a very early production vehicle (9-5-69) so that complicates things too. Can you elaborate on the ?vent in the base?. Thanks
Metuchen plant
Built 9/5/1969
Offline 70cj428
« Reply #5 on: April 13, 2024, 09:13:53 PM »
Hi Dave,
Your 70 doesn't use the small vacuum vent in the base that's mentioned above, that's a mid/late 69 CJ thing. (it delays the opening of the automatic choke on a 69, your 70 uses a manual choke cable)
The 70 base uses a plastic elbow and rubber grommet for the crankcase vent hose instead of the metal tube that the 69's use. The biggest difference (and what makes a 70 base such a pain to locate) is that there's an extra recess stamped for additional clearance around the throttle cable/carb linkage. I attached a pic from the 428 site to show this. (I circled the area in red) I have an early 70 (9/11/69) Metuchen Survivor/barn find/turd that's surprisingly original and it has this 70-style air cleaner base so I'd bet yours is supposed to have the 70 style also. The air cleaner is part of the approved emission system so I'd be surprised if Ford would use 69 model year parts on a 70 ... Hope this helps, John
Offline 70cj428
« Reply #6 on: April 13, 2024, 09:21:16 PM »
Completely unrelated to your question, but since my car was built a week after yours at Metuchen, here's a Pic or two ... I think Metuchen regular production started the first week of September so your car is probably one of the first.....
« Reply #7 on: April 13, 2024, 10:41:15 PM »
Hi Dave,
Thanks for updating me on some of the 70 differences. I am still amazed at all the many differences compared 69.
