Author Topic: drum brake backing plates  (Read 4516 times)
Offline 1969 Cale II
« on: April 09, 2024, 10:15:03 PM »
This a generic question, has anybody seen, are there photos of, numbers stamped on the backing plate outsides in the small recess near adjustor hole? 2 different Fords I have done have a 4 digit number. Wonder how wide spread it might be.
Re: drum brake backing plates
« Reply #1 on: April 09, 2024, 10:34:55 PM »
If you mean the numbers that identify the backing plates then yes . I am under the impression that the numbers  have to do with identification for diameter and brake pad width.  However I don't know of a comprehensive listing with applications. For example I only keep track of the few unique different ones for the Shelby applications.
« Reply #2 on: April 10, 2024, 06:00:41 PM »
Agree with the identification. Two makers and two different practices as far as marking
If your are number by the brake adjusting hole then they are likely Bendix made
Offline GinoJ
« Reply #3 on: April 11, 2024, 10:43:13 AM »
These are from my early 67 ( but Aug 66 ) S code Convt.  One Bendix, one Kelsey-Hayes.
Neither have numbers.
Offline AJ
« Reply #4 on: May 06, 2024, 08:05:22 PM »
I currently have 8 rear backing plates.  A mixture of Bendix 317558 317559 and KH 71086 71085
Only one of them has small number, and a letter, stamped near the adjusting hole.
On a side note,  i have a Bendix 323369 that appears identical to a 317558.  I tried but cantdetermine its original and proper application.  It functioned on my 69 Gt500 for 10 years but not its correct home.  I once owned a torino with a 9 inch so maybe i cross pollinated it back when.
« Last Edit: May 06, 2024, 08:11:33 PM by AJ »
Adrian Jacobs
70 Boss 302  Dearborn, 11/22/69, original calypso paint,  original family ownership.
70 GT500 , 02/26/69, a/c auto, candy red
Offline Shelby50069
« Reply #5 on: June 22, 2024, 01:24:40 AM »
Here?s my 69 SJ  January build
Offline Shelby50069
« Reply #6 on: June 22, 2024, 01:25:54 AM »
Other side
« Last Edit: June 22, 2024, 01:29:38 AM by Shelby50069 »
Offline Anghelrestorations
    • Anghel Restorations
« Reply #7 on: June 23, 2024, 02:14:47 AM »
Besides the Bendix and Kelsey Hayes stampings have also seen the date code stamps on the backing plates stamped on the flat spot as shown in the previous post by Shelby50069.  Decoded would be:
3468 = 346th day of 1968
3478 = 347th day of 1968
Using the Julian calendar that would be December 11 and December 12th 1968 so will assume the build date of the car is after that date.
Here is a photo of another one I had here:
20231206_185349 by Marcus Anghel, on Flickr
Marcus Anghel
www.anghelrestorations.com
Offline Aussiemach
  • Silver Level Subscriber
« Reply #8 on: June 23, 2024, 04:58:00 AM »
Bendix
Kelsey Hayes
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
« Reply #9 on: June 29, 2024, 10:26:14 AM »
Yep, you later guys nailed. Just like what I found. Is it safe to say all( generally speaking) backing plates would have this?
« Reply #10 on: June 29, 2024, 03:58:16 PM »
If I understand your statement above - Yes there were only two providers and they followed the same practices for all of theirs during this time period
