Hello All,
I am working on the car in the subject. I went to purchase motor mounts on line and I found a "significant" number of negative reviews and discussions of them not fitting which shocked me. I am not sure what is going on here, some installations seem to have went great and others totally did not fit. I also saw some discussions on here about a tall and short mount, but they were old threads with broken links and I could not make sense of the topic.
I am doing significant chassis work in this area, and my intention is to build a light weight mock up of the engine and transmission so I can check fit from time to time. I do not have the original parts to compare against so I want to be sure I have the dimensionally correct parts.
The shop manual and chassis assembly manual only call out one assembly for this installation. This should be a straightforward issue. Are the reproduction parts just not consistent / accurate?
Should I try to find another vendor? or an OEM part?
I would hate to mock something up to the wrong dimensions. Can anyone offer any insight into this issue or advice? Much Thanks in advance.
Rick
