Author Topic: Thermactor anti-back fire valve identification  (Read 3043 times)
« on: March 27, 2024, 09:29:43 PM »
Looking for help in identifying the application(s) for the pictured thermactor system 9B290 anti-backfire (gulp) valve bracket.  TIA
« Last Edit: March 28, 2024, 07:30:11 AM by 67gta289 »
Re: Thermactor anti-back fire valve identification
« Reply #1 on: March 28, 2024, 12:26:40 AM »
Looking for help in identifying the application(s) for the pictured thermactor system 2B290 anti-backfire (gulp) valve bracket.  TIA
Are you sure? In the "1967 Ford Products Engine Equipment Assembly Manual" (AM0157) pg126 (and beyond), it is Ford base number 9B289.
« Reply #2 on: March 28, 2024, 07:31:42 AM »
I sure put a 2 instead of a 9 as a prefix - thanks for catching that.  289 is for the valve, I'm asking about the bracket, which is 290.
« Reply #3 on: March 28, 2024, 05:02:23 PM »
Turns out that this is a 1967 390-4V/410/428 bracket.  A friend gave this to me, and he normally deals in Galaxies and Thunderbirds, so is likely a 428 part, which would make it the C6AE-9B290-C.  The Mustang 1967 390-4V would have used C6OE-9B290-C.  What about the GT500 428 PI engine - which of these would that have used?  The 428 PI drawing shows C6AE-9B290-C, but that is geared towards a police car not a Shelby.
« Last Edit: March 28, 2024, 08:33:22 PM by 67gta289 »
« Reply #4 on: March 28, 2024, 06:34:16 PM »
Turns out that this is a 1967 390-4V/410/428 bracket.  A friend gave this to me, and he normally deals in Galaxies and Thunderbirds, so is likely a 428 part, which would make it the C6AE-2B290-C.  The Mustang 1967 390-4V would have used C6OE-2B290-C.  What about the GT500 428 PI engine - which of these would that have used?  The 428 PI drawing shows C6AE-2B290-C, but that is geared towards a police car not a Shelby.
Ya wanna fix some more "2's" to "9's"?  ;)
« Reply #5 on: March 28, 2024, 06:49:27 PM »
A couple of pictures to add to the discussion
Given the different intake and multiple carbs the valve was not attached like the 390 Mustangs/Cougars
Hoses were shortened and the valve was mounted right above and behind the pump and was held in place by just the rubber hoses attached to valve. Yes there is an incorrect non original hose clamp in picture
« Reply #6 on: March 28, 2024, 06:51:22 PM »
The 67 GT500 would use the same part as the 67 390 4V in this instance. FYI the 67 GT500 is the same 67 428 PI engine but with duel fours added.
« Reply #7 on: March 28, 2024, 11:01:12 PM »
Guess we'll have to disagree about the bracket
Here is another picture from 67 with the bracket not attached to the valve. Thee 390 Mustang valve was not used for the GT500 application. The GT500 used the same three port valve as the 289 where the 390 used the two port. Wasn't like they installed the whole 390 Thermactor assembly and left it at that. Number of other parts are different between the two systems also.
« Reply #8 on: March 28, 2024, 11:43:56 PM »
Not really because when I said same part (Thermactor anti-back fire valve) I did not mention or mean to imply the bracket.
