Author Topic: 1969 Firewall hole size needed.  (Read 2145 times)
Offline Scott302
« on: March 26, 2024, 04:10:11 PM »
I am looking for the diameter of this hole in the center of the firewall.  The under dash main harness with a grommet and wires for the wiper, engine gauge feed harness and others pass through here.
Regards,
Scott
Scott Halseth
Ford Product Manager
National Parts Depot
MCA#01776
Re: 1969 Firewall hole size needed.
« Reply #1 on: March 26, 2024, 07:08:57 PM »
I would assume that is for underdash harness, 14401, and if I got to punch a feed thru hole for any harness, I measure the diameter of the grommet's groove and use a chassis punch.
Him
Offline Scott302
« Reply #2 on: March 26, 2024, 09:04:04 PM »
Not why I need it.  I need to verify the original dimension.
Scott
Scott Halseth
MCA#01776
Offline JohnSlack
« Reply #3 on: March 27, 2024, 06:32:45 PM »
Scott,
If nobody else answer before I get out to the shop this afternoon and slide the harness out. I'll let you know.
9F02G217159 1969 1/2 Dearborn BOSS 302 built July 10, 1969 1 day behind
Calypso Coral 2A 61 DSO V 3.91 Trac-Lok 6 Close ratio Retail Bob Brock Ford
0F02G106990 1970 Dearborn BOSS 302 built September 23, 1969 13 days behind
Lime Metallic EG 71 DSO S 3.50 Trac-Lok 5 Wide ratio Stock John E. Noyes Ford
Offline JohnSlack
« Reply #4 on: March 28, 2024, 03:37:55 AM »
Scott,
Sorry Scott I couldn't get the harness out to measure the hole for you.
Offline Scott302
« Reply #5 on: March 28, 2024, 10:03:14 AM »
Thanks for trying.
Scott Halseth
MCA#01776
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
« Reply #6 on: March 29, 2024, 05:45:13 PM »
It is 1 1/4 inch
MCA#31064
