Author Topic: 67 Exterior Mirror Mount  (Read 1855 times)
Offline harry674u2c
« on: May 18, 2011, 12:32:35 AM »
How do you seat the 67 mustang exterior mirror flanged tube nut into the door skin?
Re: 67 Exterior Mirror mount
« Reply #1 on: May 18, 2011, 09:12:03 AM »
If you can find a threaded stud for a heavy duty pop rivet tool that will work. If not a long screw that you put a nut on midway with a flat washer under. Put the nut insert under the washer and set in the door skin. Hold the screw from turning and tighten the nut to crimp the insert. Good luck Marty
« Reply #2 on: May 18, 2011, 04:44:47 PM »
Re: 67 Exterior Mirror Mount
« Reply #3 on: May 18, 2011, 07:49:06 PM »
Offline harry674u2c
« Reply #4 on: May 25, 2011, 02:33:55 AM »
Thank you for the help guys.
