Author Topic: 69 70 Mustang Speaker Cover identification  (Read 3655 times)
Offline Shelby1966
« on: March 25, 2024, 10:48:41 AM »
Please help with letting me know which mustang specific interior design does this speaker cover fit.
Part # C9ZB-18978-CW
Thanx
Re: 69 70 Mustang Speaker Cover identification
« Reply #1 on: March 25, 2024, 12:14:40 PM »
Thanx
Here is one in a 69 Shelby (Mach I) deluxe interior.
Offline Shelby1966
« Reply #2 on: March 25, 2024, 12:32:58 PM »
Bob
Thank you for the reply.
I bet if you pulled off one of your speaker covers the part # would end in DW...
CW means something different.
The CW part # cover is slightly smaller in size.
Any thoughts...
TY
« Reply #3 on: March 25, 2024, 12:44:27 PM »
Bob
Any thoughts...
TY
Yes DW. I checked some on the shelf I find that they are DW. Sorry I am only familiar with the deluxe interior style.
Offline Shelby1966
« Reply #4 on: March 25, 2024, 02:07:14 PM »
Do you have a idea what "CW" means for the specific interior
« Reply #5 on: March 25, 2024, 06:25:08 PM »
Could identify the color the grill is cast in
Offline Shelby1966
« Reply #6 on: March 25, 2024, 07:45:31 PM »
The CW speaker cover is slightly smaller than the DW speaker cover.
« Reply #7 on: March 25, 2024, 08:23:59 PM »
The "DW" speaker cover is for 1969-70 with stereo door speakers. It has a curled edge on the bottom, contours to the bottom edge of the doors on 1969-70 Mustang and Cougars.
« Reply #8 on: March 25, 2024, 09:07:53 PM »
+1 it is often the case with color-keyed interior parts that the part number suffix is used to differentiate between colors.
Offline AJ
« Reply #9 on: March 26, 2024, 12:47:53 AM »
Out of curiosity, I pulled a white speaker grill of dads 70 Boss.  AM 8 track car with white standard interior.  Grill never been off the car.   Found it to be a -cw suffix.
Adrian Jacobs
70 Boss 302  Dearborn, 11/22/69, original calypso paint,  original family ownership.
70 GT500 , 02/26/69, a/c auto, candy red
« Reply #10 on: March 26, 2024, 11:41:47 AM »
Might be the interior trim level, of the door panel, that changes the speaker cover?
The "DW" covers appear to be all the same regardless of color.
Offline hopey
« Reply #11 on: March 26, 2024, 11:42:29 AM »
Extract from the 1975 MPC. Standard vs deluxe?
1970 BOSS 302
Built 11/15/69 Dearborn
« Reply #12 on: March 26, 2024, 07:28:48 PM »
Keep in mind that you are asking about an assembly line's part number which is different than a dealer's service stock number, the "ZZ" in this case. (The documentation for the service number refers back to and says to use the assembly line part number to make, identify and inspect the part, but the dealer orders, and stocks the service number.)
The door grill is shown in the 1969 Mustang Electric Manual (AM0028) pg55, item 3, as two options, C9ZA-18978-CW, standard door trim only, and C9ZA-18978-BW, Mustangs with decor door trim and all Cougars. These are the actual Ford design casting numbers. The 70 manual shows a -EW and -FW for the same use. The difference is most likely a design change (strengthen holes or webbing are the most common). As Scott shows in reply 10, it is not color.
Offline C9ZZ-16228-B
« Reply #13 on: March 27, 2024, 12:10:44 PM »
Standard interior vs deluxe.  The standard (CW) is completely flat on the backside, made to fit up against the metal door.  The deluxe is contoured at the bottom to fill the gap where the speaker cover goes over the door panel, since the deluxe door panels (and Cougar panels) are cut out all the way to the bottom edge when used with speakers.
