Author Topic: AC Evap Expansion Valve capillary bulb retainer  (Read 2234 times)
« on: March 24, 2024, 12:06:25 PM »
Air Conditioning Evaporator Expansion Valve has a capillary bulb that is held in position with an interesting setup.  The valve assembly service part number is C6OZ-19849-A.  The retainer/clamp is comprised of four pieces, none of which were serviced separately or collectively, at least that I found.
The main copper sleeve (for lack of a better term) has a basic part number 19A634.  There are two steel plates, one through hole and one for the screw to thread into, are 19A867 and 19A866.  The screw looks to be a #8 and is 1/2" long.
This is just an observation, with pictures, just in case someone needs this down the road.
