Author Topic: '70 Boss 302 Metuchen spring/hood latch finish  (Read 2580 times)
Offline mgreene
« on: May 16, 2011, 02:21:09 PM »
Are the hood springs and latch on a '70 Metuchen Boss 302 phosphate and oil? I know the shock tower caps are supposed to be black, correct?
Also, I have a very old bottle of phosphate mix from Palmetto. Does anyone have the correct mix amount available (I can't find my instructions).
Mike Greene
Re: '70 Boss 302 Metuchen spring/hood latch finish
« Reply #1 on: May 16, 2011, 05:35:34 PM »
Quote from: mgreene [/quote
Correct
Believe those were phosphate and oil also at Dearborn and NJ
Had the same question yesterday (still have not figured it out completely :(  even emails the place but no answer yet. Did find the following not sure if its correct but it might be
http://www.scribd.com/doc/28345848/Zinc-Parkering-Instuctions-Palmetto-Concentrate
« Reply #2 on: May 16, 2011, 09:37:35 PM »
Just got an email back from Scott @ Palmetto - His response
Manganese is 14 ounces to 128 ounces water,
Zinc is 4 ounces to 128 ounces water.
Offline mgreene
« Reply #3 on: May 17, 2011, 01:40:32 PM »
Thanks, Jeff!
Offline mgreene
« Reply #4 on: June 09, 2011, 03:48:35 PM »
Quote from: mgreene on May 16, 2011, 01:21:09 PM
Correct
Jeff, what about this '69 Shelby (Dearborn) that got a SAAC Premier award? Its shock tower caps appear to be black?
http://saac.memberlodge.com/resources/0211/0211-grabbing.pdf
« Reply #5 on: June 09, 2011, 11:56:44 PM »
You didn't ask about 69 or 70 Shelby's ;) Those, we expect to see painted semi-gloss black as most had a reinforcing washer added around each shock nut - welded to the upper shock bracket. Since the welding destroyed the phosphate finish they simply painted them black to cover the new weld and the rest of the now modified part. This was a practice started on the 65 Shelby's and continued (though some may have made it through the process with no washer added or being changed out at some point) through early Shelby production and is spelled out in the rules where written down
Offline mgreene
« Reply #6 on: June 10, 2011, 07:38:16 AM »
Thanks, again!
