Author Topic: Air Conditioning  (Read 4949 times)
Offline nstearn
    • owner
Air Conditioning
« on: March 14, 2024, 07:20:35 PM »
Hello, The air conditioning in my car is currently still R12. Besides using a retro fit kit,what is everybody using? Keep in mind car will be judge by MCA in the concourse driven class. Appreciate your feed back Thanks
Norm
MCA # 94370
1966Coupe, 74, 75, 79, 84GT, 84GT350, 90GT, 91LX
1979-1993 Gold Card Judge
Offline KevinK
Re: Air Conditioning
« Reply #1 on: March 14, 2024, 08:11:54 PM »
R12 can still be found.  Its just that no one wants to be bothered playing with it. Converting everything over to R134 is often more expensive that tracking down R12.  New seals (green orings) can be used for either one.  R12 hoses do not have the barrier material to totally contain the R134.  The old hoses can be rebuilt.  The oil in the system is different between R12 and R134 so flushing is required.
To be legal, you can get a CFC certificate online.  You don't need a certificate to repair the system but primarily to handle the Freon.  Its pretty simple to repair the system.  A vacuum pump may be the hardest tool to locate, used to evacuate and leak check.  Even a gauge set is not that pricey.  If you have R12 freon in your system now, it may just be low.  Look for greasy/oily residue at the various fittings as that's a sure since of a leak. I'm not an expert but I repair my own systems.  In my line of work, we used similar hardware without the CFC issue.
Just be careful of some of the substitutes, as they often contain propane. R134 does require a certificate if you purchase it in small canisters <30 lbs.
My guess, any shop is going to require you to rip everything out and start over.  At that point R134 is a simple requirement.
MCA #33800, Gold Card 3rd Gen
BAMA Member
« Reply #2 on: March 14, 2024, 09:19:26 PM »
I'm seeing a lot of R-12 coming out of the woodwork on FB marketplace in my area, and I've picked up ten 14 oz cans over the last year that were cheaper than R134.  Right now the price range is $17 to $49 per 12-14 oz can.  I'm not in a hurry so wait for the $10-12 price range.
Offline KevinK
« Reply #3 on: March 15, 2024, 04:25:08 PM »
Right? I picked up 25 cans for under $10 each.  Ebay is a it too visible.
BAMA Member
« Reply #4 on: March 15, 2024, 05:50:38 PM »
R134A is maybe 75 percent as efficient as R12. So a lot of older cars find their air conditioning is less likely to keep the car cool inside because now the AC only cools the air to 40 degrees instead of 30.
Progress.......
