Author Topic: 68 San Jose Inner Fender Splash Shields  (Read 2400 times)
Re: 68 San Jose Inner Fender Splash Shields
« Reply #15 on: March 03, 2024, 04:06:56 PM »
How about the fender brackets on the bottom, in a previous post it was suggested that they were in the wrong position.
L shaped bracket was sandwiched between the unibody and the splash shield so that it is not visible (except for the bend below the splash shield) under the splash shield or retaining screw
Also should the rubber overlap at the top or should it get trimmed to fit.
Over lapped
« Last Edit: March 03, 2024, 04:10:20 PM by J_Speegle »
Offline bullitt68
« Reply #16 on: March 03, 2024, 06:58:18 PM »
Over lapped
Great thank Jeff. Looks like my fender bracket is installed correctly.
FYI Roger also just posted a couple of great reference photos of his original paint survivor car. Observed on his car the top shield/flap is on the front side of the metal shield and the long vertical rubber shield is on the back side .
Mike
« Reply #17 on: March 03, 2024, 07:27:53 PM »
Yes saw that and they are different from San Jose installed one for 68 that is why I separated that post to a new Dearborn focused thread so not to cause confusion in this San Jose thread
Offline bullitt68
« Reply #18 on: March 03, 2024, 09:32:04 PM »
OK great thanks. I will just install all the rubber on the same side. Roger's car is a nice example indeed
Mike
« Reply #19 on: March 03, 2024, 09:35:03 PM »
"Same Side"   As in reply #8 I hope  :)
Offline bullitt68
« Reply #20 on: March 03, 2024, 10:16:21 PM »
Great thanks Jeff
Mike
Offline bullitt68
« Reply #21 on: March 04, 2024, 02:10:03 AM »
Hopefully 3rd time is the charm.
Mike
Offline bullitt68
« Reply #22 on: March 04, 2024, 02:12:53 AM »
While we are on the subject did you notice that Rogers car has no primer showing on the inner fenders or undercoating. Was the a plant thing? As far as I know my inner should be red oxide and there show be undercoating/sound deadener applied on top off that. Hopefully this is not too off topic
Mike
« Reply #23 on: March 04, 2024, 01:48:14 PM »
How the front wheel wells were finished was a "plant thing" but also remember his was not a regular production vehicle but one of the 135 cars. If we want to discuss those you can either allot of threads on the 428CJ forum and site or we can start a different thread since its different plant and as mentioned very different cars in some areas of the build
Offline bullitt68
« Reply #24 on: March 04, 2024, 08:00:29 PM »
Thanks Jeff that makes sense. More than likely special cars like that were exceptions to some of the regular procedures for various reasons.
Mike
« Reply #25 on: March 04, 2024, 08:05:28 PM »
Yes the 135 cars were identified as race cars prior to when they were build so things like any extra weight  would have been a consideration
Offline bullitt68
« Reply #26 on: March 04, 2024, 08:11:08 PM »
Good point Jeff. Roger asked a question on the Dearborn thread regarding when the dust shields were installed, before or after the fenders are installed.
Mike
