Author Topic: 68 San Jose GT 390 Lower Radiator Support Brackets  (Read 2768 times)
Re: 68 San Jose GT 390 Lower Radiator Support Brackets
« Reply #15 on: February 27, 2024, 01:56:32 PM »
I know that you said you got new hardware from AMK but the bolts I have seen do not have the large washer. Like the ones in Jeff's pictures. Maybe it is a plant thing.
+1 Think what you found was likely from a prior repair or remove and reattached
Offline bullitt68
« Reply #16 on: February 27, 2024, 04:26:26 PM »
Hard to tell in the photos Jeff posted, but the head marking look like the AMK bolts, except it appears that they also have the large washer
Mike
« Reply #17 on: February 27, 2024, 05:47:25 PM »
The two (the fender bolt and the one from the unrestored San Jose example are very different
Fender washer has a separate though captured washer that is larger than the original bolt shown. The bolt from the San Jose car has a flared base but no washer and the head design appears to be the RBW one
Notice the comparison of diameters in the pictures below
« Reply #18 on: February 27, 2024, 06:58:10 PM »
The bolts in the AMK kit are not fender bolts. They are shorter bolts that have washers similar to the fender bolts. They are typical of Dearborn, not so much for San Jose manufacture.
Offline bullitt68
« Reply #19 on: February 27, 2024, 07:16:40 PM »
Good point. I will have to see if I can find some bolts like that.
Mike
Offline bullitt68
« Reply #20 on: February 27, 2024, 07:17:26 PM »
Thanks Jeff those are great reference photos
Mike
Offline bullitt68
« Reply #21 on: February 28, 2024, 12:43:07 AM »
Would these bolts be a better option compared to the other examples I posted
« Last Edit: February 28, 2024, 12:46:01 AM by bullitt68 »
Mike
« Reply #22 on: February 28, 2024, 12:45:14 PM »
Possibly not. Those are Grade 5, the "Y" marking on the head. Previous shown bolts were Grade 5.1, the "T" marking (it's actually and inverted "T").
« Reply #23 on: February 28, 2024, 02:38:35 PM »
Those seem to both be marked "T".
Online ruppstang
« Reply #24 on: February 28, 2024, 02:59:43 PM »
These are what I have use from AMK in the past. You cannot see it in the picture but there is an anchor on the head.
« Last Edit: February 28, 2024, 03:01:55 PM by ruppstang »
« Reply #25 on: February 28, 2024, 03:42:24 PM »
Those "T" (there are two) is/are manufacturers logo's. Each, including the "C', are in a "Y" pattern. I strongly recommend you review bolt head markings. Try the library.
Offline bullitt68
« Reply #26 on: February 28, 2024, 04:10:24 PM »
Do you have a photo of the right bolts?
Mike
Offline bullitt68
« Reply #27 on: February 28, 2024, 04:14:14 PM »
Well I have anchor head bolts. I will check my AMK catalogue
Mike
Offline bullitt68
« Reply #28 on: February 28, 2024, 04:42:33 PM »
I tried cross referencing all of my AMK catalogs and the Assembly Manual etc and have not been able to find a match. I just need to know what the correct head markings are so I can try to source them as they do not soon to be available in the aftermarket
Mike
« Reply #29 on: February 28, 2024, 06:41:52 PM »
Do you have a Ford hardware part number? I recommend that you get into the habit of using a part number. It makes the search by others easier. See attached.
