Author Topic: Restoring Aluminun intake  (Read 10507 times)
Offline JKWilson
Re: Restoring Aluminun intake
« Reply #15 on: February 06, 2012, 11:24:09 AM »
Jeff I recently "discovered" what produces a pretty nice result. I used fine glass bead with a blasting pressure of approx. 40lbs. I had done some previous blasting with a low pressure and forgot to turn the pressure back up on my booth regulator. The resulting finish is pretty bright (which surprised me after I began!). I had none of the dull flat finish normally seen with higher pressures. I've done about 6 pieces now with the same results.
« Last Edit: February 06, 2012, 11:26:10 AM by JKWilson »
« Reply #16 on: February 06, 2012, 10:34:14 PM »
Tried walnut shells and other things  have not gotten a great results as of yet. Not looking for the bright just blasted look nor the rough surface most blasting produces but instead a semi-smooth darker finish (can brighten up the machined surfaces) you find on new intakes you see out of the box
Offline 266ks
« Reply #17 on: May 08, 2013, 12:46:47 AM »
The finish is the same as a new edelbrock intake manifold.
