Author Topic: Fuel line clip location  (Read 929 times)
Offline RichardM68
« on: February 22, 2024, 02:49:24 PM »
Hello.  The PO of my car routed the fuel line on the passenger side for some reason.  I'm relocating it to where it came from the factory.  I'm trying to locate the locations and types of fasteners used at the factory.  Going through the pics on here, well, it's a lot of searching.  I'm wondering if there's a thread about this I'm not seeing.  Or, if someone has better info.
So far, the below pics are the only ones I've found that are useful to me.
Also, for reference, I bought a kit from CJ Pony.  https://www.cjponyparts.com/brake-and-fuel-line-clip-kit-8-cylinder-hardtop-1968-1968/p/BFK13/.
-Richard
1968 Fastback J code.  My -exact- first car!  8F02J166xxx.
Re: Fuel line clip location
« Reply #1 on: February 22, 2024, 03:31:40 PM »
-Richard
The type of each clip and all of the different locations of each are illustrated in the 68 chassis assemblyline manual available from all major Mustang Parts vendors.
Offline RichardM68
« Reply #2 on: February 22, 2024, 07:00:45 PM »
The assembly manual doesn't provide detailed enough locations for me.  I want to be very close to how it came from the factory.  I have new sheet metal (PO installed) and there are no holes to use.
Offline dkknab
« Reply #3 on: February 22, 2024, 07:16:28 PM »
I'm assuming we're talking about a 68 coupe with v8 correct? Where was it built? I'd be happy to share the route of my fuel line in my 68 coupe Metuchen built car if that's helpful.
David Knab
289 2V, AT, PS
Nugget Gold Interior
Offline RichardM68
« Reply #4 on: February 22, 2024, 10:38:50 PM »
Hi.  Sorry.  It's a 68 Fastback J code.  Dearborn.  I'd still be interested in your routing/clips.  It would certainly get me closer than the assembly manual, and guessing.
Thank you,
-Richard
« Reply #5 on: February 22, 2024, 11:33:22 PM »
Thanks might consider adding that info to your signature. You'll be asked that just about every time you ask a question here
Think these are the clamps and retainers for your application
Sorry they are not all pretty and clean  :)
« Reply #6 on: February 22, 2024, 11:56:12 PM »
Sorry my response was based on the factory holes still being there. That is a lot of replacement sheet metal repair If all of the holes have been lost. FYI the holes on a Metuchen built car and a Dearborn built car are going to be real close if not exactly the same.
Offline RichardM68
« Reply #7 on: February 23, 2024, 10:35:49 AM »
Hi Bob.  No worries.  I should have been clearer in my original post.  Usually I write too much info and confuse the question.
Not all of the holes have been lost to new sheet metal.  The PO just plug welded some of them!  I have no idea what aesthetic he was going for.  Thankfully he's not a great welder and I can sometimes tell where the hole was.  Oddly he welded the hole where the fuel line comes through the front fender apron.  I was able to re-drill it based on pics from here and him less than perfect weld.
Offline RichardM68
« Reply #8 on: February 23, 2024, 10:37:02 AM »
Jeff... you're the man!  I owe you another few beers.
I'll update my signature shortly.
-Richard
« Last Edit: February 23, 2024, 04:14:32 PM by J_Speegle »
