Hello All, I have a set of original styled steel wheels I am looking to have re-chromed and I am running into the issue that all the chrome shops I have inquired with do not separate the center chrome section from the outer section or re assemble. As you are aware, the wheel is made in two part and riveted together. The center is chromed and the outer wheel is painted then assembled with large rivets. What I would like to do or have done is the wheel separated, the center re chromed and the outer section re painted. Then have it re assembled.
Does anyone know if someone does this or can point me in the right direction. If no one does this and there are so many styled wheels out there from back in the day, I was thinking of going into business restoring these wheels if I could fine all the stuff needed to do it. Obviously there are many factors to consider including the riveting process.
I spoke to expert chrome shops in CA & PA and both say they can separate and re chrome but not re assemble. That's the issue. Obtaining rivets and safely re assembling seems to be the issue.
Anyone have any resources they can direct me to?
Thanks!
