Author Topic: Getting a starter stamp made  (Read 4899 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: May 13, 2011, 09:31:15 AM »
Is this the correct stamp I'll need for my MAR 66 C-Code?
66 Metuch Conv
Nightmist, Std Blu Int
Re: Getting a starter stamp made
« Reply #1 on: May 13, 2011, 06:27:04 PM »
Are you asking if the stencil/stamp design is correct or asking about the engineering number.
IMHO my answer to both would be no - just from the other examples I have
Offline Twilight65
  • Gold Level Subscriber
« Reply #2 on: May 13, 2011, 06:36:37 PM »
Bryan,
I believe the engineering number would be C4ZF 110001-A for your car.
Dave
« Reply #3 on: May 13, 2011, 06:57:17 PM »
+1
Offline bryancobb
  • 2009 Ridn' Around
« Reply #4 on: May 13, 2011, 07:22:28 PM »
Well I ordered the wrong engineering number.  Is the date coded correctly for a MAR 66 car?
Jeff,  what characteristic(s) of the design do you see as being incorrect?
I need to order another one and I wannt to get it right.
Bryan
« Last Edit: May 13, 2011, 07:28:43 PM by bryancobb »
66 Metuch Conv
« Reply #5 on: May 13, 2011, 10:15:50 PM »
The date stamp should be a number followed by 2 letters.  For instance, 6AB would be second week of January, 1966.
« Reply #6 on: May 13, 2011, 10:43:05 PM »
First you've done a fine job so far - these often take me over 20 hrs since there are so many different features in the design
Below you will find a copy of your design with some alterations - Not near perfect just a quick adjustment to illustrate some points
As a note and after looking at a fair share of these I believe and have found evidence of the border going around the whole outside of the design and a matching line between the date and the main section of the stamp. From examples it appears that the date section was separate and replaceable like the two slipped together as on some examples the date section was not fully locked into place and was slightly higher than the rest of the stamping. So would correct that
1- 12 VOLT - was reduced in size
2- (in blue circle) needs IMHO to be bolder
3- MADE IN USA reduced to match the size of VOLT and the whole set of words moved closer to the center
4- FoMoCo enlarged within the present oval
5- Brackets (may have originally been a complete frame or at least a partical frame
6- Agree with Charles the date would be a letter followed by two or three letters
7- And as mentioned earlier needs the C4AF changed to C4ZF or there may have been a C5 or C6 used by mid 66 production
Not sure what the size of the file your working with is. I normally make the design 5-10 times the final sizing to improve the details often (in designs with really fine lines) just submit the graphic file but in simpler designs I just provide camera ready on a piece of paper
« Last Edit: April 01, 2023, 02:39:32 PM by J_Speegle »
Offline bryancobb
  • 2009 Ridn' Around
« Reply #7 on: May 14, 2011, 09:05:09 AM »
Thanks for the input guys.
66 Metuch Conv
Offline bryancobb
  • 2009 Ridn' Around
« Reply #8 on: May 14, 2011, 09:15:56 AM »
Here's the one I used as an example.
66 Metuch Conv
« Reply #9 on: May 14, 2011, 07:08:51 PM »
Thanks - believe it shows a number followed by two letters as mentioned
It does appear to be very similar/the same as the examples I have  (have three different versions - 1 FoMoCo and 2 different AUTOLITE)  except for the border/bracket on the upper right. I have other examples that show a border at the bottom left and possible evidence of bands between the corners that might have made up a complete border that didn't produce well in the stamp applications. In your examples right side I wonder if the stamp slipped downward or if the stamp did not stamp that area well and the worker reapplied the date.
Offline Skyway65
« Reply #10 on: May 15, 2011, 10:09:40 AM »
Nice work Bryan.  Does anyone have any info on what a Jan. '65 Dearborn 6 cyl starter stamp would look like? "I gotta get me one of them!"  ::)
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline bryancobb
  • 2009 Ridn' Around
« Reply #11 on: May 15, 2011, 10:40:42 AM »
Thanks Gary,
I'm a designer at a ASME Pressure Vessel Builder and do AotoCAD daily.
I also have been a sign painter.  These two fit together nicely.
66 Metuch Conv
Offline Twilight65
« Reply #12 on: May 15, 2011, 01:49:58 PM »
Here's a picture of a starter and it has a lot more border around the stamping than most I have seen.
Dave
Gary - you have a 170 CI right. I believe your starter engineering number would be C4DF 11001-A or B. I'll look for a picture.
Offline Skyway65
« Reply #13 on: May 15, 2011, 02:41:35 PM »
Actually, it is a 200.  Engine was assembled in Dec of '64.
Gary Schweitzer
MCA #00181
Traverse City, MI
« Reply #14 on: May 15, 2011, 04:58:23 PM »
Dave - thanks for posting - interesting second border on the right side I have not seen on other examples - though we all know that the border seems to be the one thing that does not show up well after all these years. One reason I've left this stamp undone, at this point. Don't want to make one and find out its wrong in some major way
