Author Topic: 69 vs 70 hood catch support bracket  (Read 1831 times)
Offline grabberblue
« on: January 30, 2024, 10:15:35 PM »
I'm currently wanting to replace the hood catch center support bracket on a 70 Mustang. I understand that they're different between a 69 and 70 Mustang. Specifically the bolt hole arrangement where it attaches to the radiator support bracket. I have a picture of what i believe to be two support brackets (attached). If someone has a picture of a 69 and 70 support bracket that they could take a picture and share I would greatly appreciate it.
Thank you in advance.
Offline 6t9m1
Re: 69 vs 70 hood catch support bracket
« Reply #1 on: January 31, 2024, 07:35:37 AM »
Early 69 production not sure how long it ran for. This one is dated 7  29  D2
May69 Mach1 SanJose 351toploader
Offline grabberblue
« Reply #2 on: January 31, 2024, 12:44:29 PM »
Hi 6t9m1,
Thank you for getting back with me! Having a picture of a 69 hood catch support bracket you can definitely tell the difference.
Dan
Offline 6t9m1
« Reply #3 on: February 01, 2024, 06:29:59 AM »
Hi Dan
Note that I included the date code stamping with my picture of an early one I have.
That date code would be 29 July 1968
Also I would not be surprised if the 70 style bracket you posted was being used sometime during the 69 production run.
Hopefully someone will know if there was a change and around when it happened.
I might also add that when these brackets are assembled on the vehicle it would be hard to tell the difference if the 24 inch radiator is used.
« Last Edit: February 01, 2024, 08:03:27 AM by carlite65 »
Offline grabberblue
« Reply #4 on: February 01, 2024, 03:28:43 PM »
Hi 6t9m1,
Thank you again for the great input. I looked for the date code in the picture you provided but I don't see it. When you get the chance, could send the picture with the date code?
Thank you,
Dan
Offline 6t9m1
« Reply #5 on: February 03, 2024, 05:53:01 AM »
Both dated areas circled.
Offline grabberblue
« Reply #6 on: February 03, 2024, 02:13:43 PM »
Thank you for posting the pictures!
