Author Topic: WTB: '68 big block fixed a/c idler pulley  (Read 903 times)
« on: January 06, 2024, 02:33:33 AM »
Looking for a good used fixed a/c idler pulley assembly for a '68 390/428.  This is the one that mounts below the compressor.
Original Ford p/n C8AZ-8678-B
*Bought one, thanks
« Last Edit: January 08, 2024, 01:20:54 PM by CharlesTurner »
Re: WTB: '68 big block fixed a/c idler pulley
« Reply #1 on: January 06, 2024, 09:20:20 AM »
I have one that is cast and a two hole. I think what you are looking for is pressed steel and three holes?
« Reply #2 on: January 06, 2024, 11:30:08 AM »
Should be a 3 hole steel.  I think the 2 hole cast would be for a small block, at least that's what is on a '68 GT350 that I'm working on also.
Offline Scode67FB
« Reply #3 on: January 07, 2024, 01:47:19 AM »
I'm sure I have one of these idlers. I don't know if there are differences between 68, 69 and 70.
« Reply #4 on: January 07, 2024, 02:01:43 AM »
68/69 are supposed to be the same
Offline 67350#1242
« Reply #5 on: January 07, 2024, 12:17:12 PM »
Mansfield shows they have a NOS  C8AZ-8678-B
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
« Reply #6 on: January 07, 2024, 04:43:30 PM »
2 holes cast for a 67 early 68  Big block also and they are easily confused but they are a different shape and will not interchange.
« Reply #7 on: January 07, 2024, 04:46:25 PM »
1968-69 is small, flat bearing. 1970 has a slightly larger, diameter flat bearing. 1970 normally, also has a D0AA.. casting number on it.
« Reply #8 on: January 08, 2024, 12:03:41 PM »
I had contacted Bill already, he didn't have any.  Thanks
