Author Topic: Looking for Used or or NOS ignition coil ink stamp pictures  (Read 1713 times)
Online Kyle Zammit
« on: January 03, 2024, 04:58:32 PM »
Hi all,
I am looking for pictures of NOS Original or used Original yellow top ignition coil showing the silver ink stamp with any date code. Just looking for the ink stamp position very top or very lower or centre ??
Thanks Kyle.
Re: Looking for Used or or NOS ignition coil ink stamp pictures
« Reply #1 on: January 03, 2024, 05:44:24 PM »
Here's a couple. This is a 1965 coil that was painted black, stamped with silver ink and a black painted bracket attached, you can see the negative on the stamp on the inside of the painted bracket. Also is a dimension drawing for a stamp if you get one made. The last is a representation of date codes for 65 and 66 Mustangs. I don't remember the font size. I think it was 12 point, or the font type, but you can use the information as you see fit.
JIm
« Reply #2 on: January 03, 2024, 08:53:32 PM »
https://www.concoursmustang.com/forum/index.php?topic=13325.msg81764#msg81764
https://www.concoursmustang.com/forum/index.php?topic=2947.msg15690#msg15690
Just a few of the examples I have pictures of have produced and  provided these for years. Pain to to get stamped on coil either using the roll on or roll over methods. But if you get a wiggle in the print there are a number of examples where originally they had similar wiggles in the stamping. Hope this helps
Online Kyle Zammit
« Reply #3 on: January 04, 2024, 04:11:59 PM »
Thanks Jim and Jeff.
Online Kyle Zammit
« Reply #4 on: January 05, 2024, 06:11:21 PM »
What paint or Ink should I use please?
« Reply #5 on: January 05, 2024, 06:40:08 PM »
Recently I've been using ink. Paint can get stringy and have more push out it seems but you want a little of that IMHO for the later borders at time
Just from the local craft store
« Reply #6 on: January 06, 2024, 02:03:25 PM »
I've used Silver "1250 Aero Ink" in the past. It is epoxy based stamping ink. It is permanent. Epoxy based inks are what Ford used. The problem with epoxy based inks is that the ink pad is a one time only use because you can't remove the epoxy ink from the pad. In other words, you toss it. Usually you can clean the stamp with an appropriate solvent.
The bad news is that apparently the only available 1250 Aero Ink colors are black and white. I did not search e-bay.
Online Kyle Zammit
« Reply #7 on: January 06, 2024, 03:47:58 PM »
Thanks a lot Jeff and Jim.
