Author Topic: 1970 Strut rod question  (Read 2511 times)
Offline HDAshmore
« on: January 01, 2024, 05:36:29 PM »
Team,
I have two Dearborn cars.  Both 70, one Boss 302, the other 351C Mach1.  Both made after January 1970.
I attached a Pic of my strut rod without the cotter pin.  I know that mine are of unknown origin since car was completely stripped and painted gloss black on all suspension before I owned it. My Mach has same nut and essentially looks the same so no pic attahed.
The pic with the cotter pin has me questioning what is correct.  I can't remember origin of this (first) pic but I just noticed cotter pin and now I'm clueless.  Did different factories use different strut rods?  Why a cotter Pin on the end instead of in conjunctiontion with castle nut?
When it's time to do both my cars I just want to make sure I'm doing what's right.  I'm along ways off from doing but never to early to source correct parts.
As always, thanks!
Dan in kansas
« Last Edit: January 01, 2024, 08:12:39 PM by HDAshmore »
Re: 1970 Strut arm question
« Reply #1 on: January 01, 2024, 08:16:07 PM »
You need to do what I just did. Look in "Ford Car Parts" (aka MPC, 75 ed, available in the library) section 30, Steering, for both Ford base numbers 3A187 and 3468. I found a cotter pin, 72035-S, referenced used for what you got.
Now, I'm going to state that this cotter pin is not referenced in the "70 Mustang Chassis Assembly Manual", but it is shown on the "1969 Mustang Chassis Assembly" drawings (AM0030, pgs 31-33). Why you got both with and without uses I'll leave to the "wizards".
Re: 1970 Strut rod question
« Reply #2 on: January 01, 2024, 10:03:31 PM »
Team,
As always, thanks!
Dan in kansas
Dan the the 69 and 70 Shelby (after aprox 4/69) ,69/70 Boss 302 and Boss 429 used a different heavy duty strut rod then the regular Mustang with the cotterpin. The regular 70 Mustang had a similar heavy duty strut rod without the cotter pin. The 69 Boss used a heavy duty strut rod with the cotter pin and the regular Mustang and 70 Boss used the one without.
« Last Edit: January 03, 2024, 11:17:44 AM by Bob Gaines »
Online AJ
« Reply #3 on: January 02, 2024, 12:09:33 AM »
If it helps, here is pic of the strut and nut on my dad?s 70 Boss 302 as it left Dearborn.  Has never been disassembled.
Adrian Jacobs
70 Boss 302  Dearborn, 11/22/69, original calypso paint,  original family ownership.
70 GT500 , 02/26/69, a/c auto, candy red
Offline HDAshmore
« Reply #4 on: January 02, 2024, 03:07:26 AM »
Team,
Thanks I'm more informed but still uncertain.
Both cars Dearborn 1970.
My Mach 1 351 C built in February should not have castle nut and cotter pin?  Which it currently does not so may be correct?
My March built Boss 302 should have castle nut and cotter pin which it currently does not, so it is NOT correct?
Does it matter what plant any of them are built?
Dan in kansas
Offline boss167961
« Reply #5 on: January 02, 2024, 03:54:49 AM »
I reckon this is the reply that is most interesting. Nothing beats the physical evidence of an untampered with car that has a known history from birth to current.
I note that the assembly manual shows on p33 that there are two strut rods per car for  [I quote] 1970 Mustang & Cougar 8 cyl & 250 CID 6 cyl [end quote] with the part numbers shown as [I quote] 3A100 L.H
3468 R.H.[end quote].
That is, there is no mention in the manual of any different versions of strut rod between B302 and non Boss cars, or indeed between *any* of the engine variants across the Mustang range.
Further, the assembly manual also clearly shows just one nut on the threat end of the strut rod. It is not shown as a castle nut alone or as well as a std nut. Nor is a cotter pin shown.
But what really interests me is why the hell you would fit a cotter pin at the end of the rod when it is so far away from the castle nut that it cannot even engage with the castle nut?thereby negating the whole point of a normal castle nut and cotter pin setup???
Soooooo?.does anybody out there know what car the pic comes from which shows a strut rod with secondary castle nut and cotter pin? What is the car?s history and provenance? Is what is shown in fact a mod made by a previous owner?
Martin
« Last Edit: January 02, 2024, 07:12:02 AM by boss167961 »
Offline HDAshmore
« Reply #6 on: January 02, 2024, 11:55:22 AM »
Oops I missed AJs post and pic.  So my 70 Boss 302 is the same as his unmolested.  Okay so I'm feeling better, but wish I never saw a Pic with a cotter pin and castle nut.  Ill leave it as a Leonard Nimoy "Unsolved Mystery" I guess :).
 Martin I agree with your question, what does the cotter pin do if not engaged in castle nut?  Maybe it's just a last minute failsafe if the nut unscrews completely and the pin keeps the strut rod from pulling out? 🤔
« Reply #7 on: January 02, 2024, 07:01:32 PM »
Here are some comparison pictures of the big suspension Boss strut rod I was talking about . The one on the right with the wide cross section (think squished out) where it bolts to the control arm is the big suspension Boss strut rod. The smaller one on the left is the regular Mustang. Notice both have the cotter pin hole on the end. I am the first to admit I am not well versed on 70 Boss cars. If this strut Rod is 69 Boss only then excuse the confusion. I assumed it was a D0 (70) part just like the BOSS 302 spindle is a D0 (70) part even though it is on a 69 car. That may not be the case. I am hoping one of the Boss authorities that frequent this forum will give a ruling on if the 70 Boss strut rod is the same as the regular 70 Mustang or not and if so what is the difference.
Offline RocketScientist
« Reply #8 on: January 02, 2024, 09:32:18 PM »
Hi Bob, out of interest what have you seen on Shelby's, as 69/70's are a rarity where I live.
Brad
« Reply #9 on: January 02, 2024, 10:38:27 PM »
Brad
Typically after approximately 4/69 is when all of the Shelby cars got the F60X15 tires (except Hertz) they also got the big suspension which consisted of the big bearing spindles (because of the F60X15 ties)that are made to accept the larger diameter 70 style tie rod ends,different heavy duty strut rods and larger diameter 70 style tie rod ends. Bob
« Last Edit: January 02, 2024, 10:45:51 PM by Bob Gaines »
« Reply #10 on: January 02, 2024, 10:49:46 PM »
The 4/69 approximate date is also when Boss 302 started production . They also used the F60X15 and space saver spare.
Offline hopey
« Reply #11 on: January 02, 2024, 11:33:49 PM »
Bob, it is my understanding that the squished out version was only used in 1969 BOSS. In 1970 all strut rods were the same, including the BOSS302.   What I do not know for sure is whether that included the 1970 BOSS429.
Also a page from the October 1969 revision of the MPC. Shows the replacement for the 69 BOSS302 squished rod is the standard 70 strut rod.
« Last Edit: January 02, 2024, 11:40:19 PM by hopey »
1970 BOSS 302
Built 11/15/69 Dearborn
Offline HDAshmore
« Reply #12 on: January 02, 2024, 11:48:24 PM »
Bob, AJ, jim and Hopey.
Thanks all for the responses and research.  I will look at all my strut rods to see if I'm good with 70 style.  I learned a lot as usual.
Bob I owe you the first beer come Columbus.
Thanks again all
Dan
« Reply #13 on: January 02, 2024, 11:54:37 PM »
Bob, it is my understanding that only the 1969 BOSS302 got the squished out version. In 1970 all strut rods were the same, including the BOSS302.   What I do not know for sure is whether that included the 1970 BOSS429.
You may be correct but the books have been wrong before. It doesn't surprise me that the 70 Boss strut rod was the same as the 70 Regular Mustang . The 70 regular Mustang used a bigger bearing spindle (spindle not the same as the Boss)and tie rods. Less parts for more applications.  I too am curious about the B9 application. The MPC seems to indicate it was different yet again for a total of 3 different strut rods used in 69 if you go by the MPC . The big suspension equipped 69/70 Shelby's got the same strut rod as the Boss 302. I have dissembled quite a few 69/70 Shelby's over the years that had them ,the B2 spindles and the bigger tie rods. Those odd and rare parts typically got switched out for more common regular Mustang parts not the other way around.
Offline boss167961
« Reply #14 on: January 03, 2024, 01:59:30 AM »
Confused.
I have two pairs of strut rods. One set I have just removed from the car. Whilst there were many wrong or repro parts on my car, judging by the pitting and ageing of the ones I have removed, I believe they are probably original to the (June 70 Metuchen built) car. That set does have the squished out control arm mount face but no cotter hole.
The set I am in the process of fitting are mint refurbed originals I got from JD at Allclassic. These also have the squashed out control arm mount face and also have no cotter pin hole.
More interestingly, the picture below is a shot from JDs 1970 stock page where it states that these strut rods are for all Mustangs 70-71 including Boss. Again, this would fit with what the 70 assembly manual shows.
And I trust JD implicitly and he is both a qualified Mustang judge and has never let me down in getting the correct Boss specific parts for my car. He knows his Bosses. So I suspect that this means the squished out control arm mount face is a non issue for 70 model Bosses of any type???.
So where does this and all the discussion above leave us on the cotter pin issue? I?m gunna shoot JD an email to see if he is aware of the cotter hole rods.
Martin
« Last Edit: January 03, 2024, 02:06:59 AM by boss167961 »
