Author Topic: FE oil gallery check valve  (Read 1375 times)
« on: December 31, 2023, 07:29:58 PM »
I see that the FE has an oil gallery check valve, identified in the 1960-68 MPC as part number C4TZ-6026-A, but identified in the 1965-72 MPC as 383024.
Are these available, because I can't seem to find anything?
The picture includes MPC listings, illustration, and pictures of the part.
TIA John
Re: FE oil gallery check valve
« Reply #1 on: December 31, 2023, 07:57:53 PM »
« Reply #2 on: December 31, 2023, 08:49:08 PM »
Jim - thanks for checking.  Since that is a manual of unknown (to me) origin, I'll be a better referee than in the NFL and give the nod to Ford documents.  I went back and checked seven single-year Ford car parts & accessories catalogs, as well as three different master parts & accessories catalogs, and updated the attached file.
The original design used part B8A-6026-A, per P&A catalogs through 1964.
In 1965 the part designated was C4TZ-6026-A.
In the 1975 dated MPCs, the 383024 number was used.
It dawned on me that the Obsolete, Supersede, Interchange catalog might help, and it sure did.  The C4TZ-6026-A was replaced by (RB) 383024-S.  There is no mention of B8A-6026-A.
Since all of these clearly state an "air bleed" function, these are not a simple plug.  Confirmed by the one I carefully extracted a few days ago.
Offline mtinkham
  • That'll be easy
« Reply #3 on: January 02, 2024, 01:44:00 PM »
Thank you for sharing John. What was your method of extraction, if you don't mind sharing?
« Reply #4 on: January 02, 2024, 01:50:58 PM »
Since it is inserted from the front of the block, after I removed the corresponding cup plug at the rear, I inserted a 1/4" diameter rod of sufficient length and proceeded to tap lightly with small hammer.
« Reply #5 on: January 02, 2024, 01:54:21 PM »
There's scant information out there, I've searched all three part numbers and a variety of terms.  Very interesting.
Offline preaction
« Reply #6 on: January 02, 2024, 04:03:32 PM »
As a regular FE user I have not heard or known of this device on a 390/428 block. Very interesting.
« Last Edit: January 02, 2024, 05:18:19 PM by carlite65 »
