Author Topic: Shaker Hood Scoop restoration ?  (Read 2102 times)
Offline rcgt350
« on: December 30, 2023, 01:41:32 PM »
Before I remove the paint from my Shaker Hood Scoop, I?m looking for suggestions on stripping the paint. Is there a media I can use that won?t take away from the smooth aluminum finish? I have bead blast cabinets only for doing this.
1967 GT 350 W White
1970 Boss 302 GG Restoration in progress
2012 Boss 302 C Orange
1930 Ford Model A 4 Door Deluxe Town Sedan
Re: Shaker Hood Scoop restoration ?
« Reply #1 on: December 30, 2023, 11:40:58 PM »
How about chemical stripping?
« Reply #2 on: December 31, 2023, 04:41:47 PM »
Try:
"Krud-Kutter", available at Home Depot;
"Goof-Off", available at Home Depot;
"Jasco", available at Home Depot;
There are other paint removers out there. As always, read the WARNINGS, and heed them. Try what ever you select on a small section.
I used a combination of those on a aluminum Shelby air cleaner top. I also lowered the air pressure on my bead blaster to 75-80 pounds and used glass beads, 40-80 grit - "gently". I have another happy Shelby owner.
« Last Edit: December 31, 2023, 05:20:39 PM by jwc66k »
Offline K-HESS
« Reply #3 on: December 31, 2023, 05:27:28 PM »
I have used walnut shells with great results. Much slower then other abrasives but leaves a nice smooth finish.
« Reply #4 on: December 31, 2023, 08:01:27 PM »
The only problem I have with walnut shells is dumping my glass beads from my blaster cabinet, then dumping the shells when I'm done. It gets "messy". That's why I drop the pressure and use the glass.
Offline rcgt350
« Reply #5 on: January 08, 2024, 12:04:29 AM »
So I went ahead and have  been stripping the paint with #8 Glass bead @ 80PSI
Its slow but working quite well with no distortion to the scoop and spacer at all.
A good workout for the air compressor! Ill post a couple pictures when done.
Thanks for all your input.
1967 GT 350 W White
