Author Topic: Speedo gear lube?  (Read 1451 times)
Offline 68 S Code
Speedo gear lube?
« on: May 11, 2011, 12:00:44 AM »
The Osborn assembly manual shows that the gear shaft and the gear is to be lubricated with graphite grease. I think only dry graphite is available. What so you guys use?
Offline TLea
Re: Speedo gear lube?
« Reply #1 on: May 11, 2011, 07:56:16 AM »
dry graphite is fine. don't use too much
Offline 68 S Code
« Reply #2 on: May 11, 2011, 09:17:49 AM »
The dry graphite between the shaft on the end and the gear sounds like it will stay in place but don't think it should go on end of gear which is exposed inside the tranny?
