Author Topic: Original Tie Rods 67/68/69/70  (Read 4560 times)
Offline Anghelrestorations
    • Anghel Restorations
« on: May 10, 2011, 07:21:26 PM »
For those of you looking to complete your front suspension with original concourse correct pieces, I have a limited number of sets of original tie rods that will fit either 67/68/69 Mustangs (small suspension) or 70 Mustangs and Boss 302 and 429 (large suspension).  This is the tie rods with the adjusting sleeve included and these are all assembly line units taken off cars over the years and restored back to original condition.
With or without paint dabs depending on your preference.
67/68/69:
Outer C7ZZ-3A130-A
Inner C7ZZ-3A131-A
$450 per set
70:
Outer DOOZ-3A130-B
Inner DOOZ-3A-131-B
$550 per set
Call or email with questions
Azscj428@gmail.com
602 628 2522
Marcus
Marcus Anghel
www.anghelrestorations.com
Offline Stangly
  • Gold Level Subscriber
Re: Original Tie Rods 67/68/69/70
« Reply #1 on: May 28, 2011, 02:33:15 AM »
I recently cleaned up my original tie rods, they look good and feel tight.  I am completely puzzled on how to apply some new grease, was wondering if you would share your trick.
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
« Reply #2 on: May 28, 2011, 03:23:24 AM »
There actually is no reason to add grease to these tie rods, since they are sealed units.  If you cut one apart you will actually see that they have a plastic insert that acts like a lubricant - so there is no need to grease them.  In many ways it makes the units more reliable to be sealed as they would not dry out that easy, or allow contaminents to enter into the tie rods.  Many cars today are the same way with not having any zerk fittings on suspension components.
Marcus Anghel
Offline Stangly
« Reply #3 on: May 28, 2011, 04:41:52 PM »
That is great news because I was hoping to use my originals.  I looked at the tie rod ends and can see the plastic insert you referenced.  On another note I was sent a private message and was referred to you for rebuilding control arms.  Is this something you are still doing?
68 Coupe J-Code
2001 V6 Laser Red
« Reply #4 on: May 29, 2011, 01:02:09 AM »
Yes, I am doing control arms and most of the front end suspension these days plus alot of plating work on various pieces...other than chrome.  Let me know what you need and send me some pictures and we can discuss.
My email:  azscj428@gmail.com
Marcus
Marcus Anghel
Offline Stangly
« Reply #5 on: May 29, 2011, 12:46:14 PM »
Will do, thank you again for the help.
68 Coupe J-Code
2001 V6 Laser Red
« Reply #6 on: June 17, 2011, 01:02:17 PM »
Adding some photos on here for a set of the larger suspension Boss/70 Mustang tie rods that I just finished - for reference.  I have a few more sets left for those that need them.
Marcus Anghel
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #7 on: June 17, 2011, 01:13:28 PM »
Any chance of a set of 66 power steerings?
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #8 on: June 17, 2011, 04:37:01 PM »
I would need to look around and see what I have left.  Most of the suspension requests I get are related to the 67-70 components.  Or if you have an original set I can always see what they look like and refinish yours as an alternative.  Send me an email if interested.  azscj428@gmail.com
Marcus Anghel
