Author Topic: Correct finish for 70 Mustang front end castle nuts  (Read 908 times)
Offline boss167961
« on: November 27, 2023, 04:14:21 AM »
Metuchen 70 Boss 302, but likely a question relevant to all 70 Mustangs. Rebuilding my entire front end with restored OE and NOS parts. As a final detail, can someone please confirm that all the castle nuts would have been phosphate and NOT yellow cad?
« Last Edit: November 28, 2023, 12:24:43 AM by J_Speegle »
Re: Correct finish for 70 Mustang front end castle nuts
« Reply #1 on: November 27, 2023, 08:14:30 PM »
Are you asking about the ones used on the steering or the spindle to upper and lower A arms?
Yes the same hardware would be the same between Boss 302 and other Mustang models.
Offline boss167961
« Reply #2 on: November 27, 2023, 11:37:20 PM »
Gday Jeff. Good to hear from you. I am referencing the nuts that attach the upper control arm ball joint to the spindle and which attach the tie rod ends to the spindle.
Martin
« Reply #3 on: November 28, 2023, 12:33:51 AM »
Only came up with examples that were clear for Dearborn examples. Given how close and because they often shared the same suppliers for other parts I think they would be the same
On used or aged originals it appears that they were likely zinc but we know that dichromate doesn't hold up well over time and I think they were zinc dichromate. Sure if that statement is incorrect someone will offer that opinion.
Examples from two different cars.
Three examples from another car
And finally examples from a very low mileage (just over a thousand miles reported) example
Hope these help
« Reply #4 on: November 28, 2023, 01:27:47 AM »
Hope these help
To others who are not aware zinc dichromate (gold) is a protective process that goes over the zinc silver. The zinc dichromate has to have the zinc silver to stick to. As the zinc dichromate wears off only the zinc silver is left.
Offline boss167961
« Reply #5 on: November 28, 2023, 04:45:27 AM »
Excellent. As ever, thanks so much Jeff. As an aside I notice it also looks like the bolts which secure the brake caliper to the spindle are also zinc dichromate  - I didn?t know that
« Reply #6 on: November 28, 2023, 12:24:21 PM »
Not Jeff but I think that you are being tricked by the lighting in the picture. The caliper to spindle bolts are typically zinc phosphate.
Offline boss167961
« Reply #7 on: November 28, 2023, 05:27:12 PM »
Thanks Bob
« Reply #8 on: November 28, 2023, 09:06:30 PM »
Think boss167961 you looking only at the last set of pictures and agree its a lighting issue from a second source so the angle changes the "look" Check out the middle group of pictures to see a better representation of the original find that matches the phosphate and oil finish. Also, general comment, try and find multiple examples to confirm details since there are times where a very nice or low mileage example has been "helped" by current or past owners to make them a little  ::) more presentable
