Author Topic: Distributor Decode Help  (Read 2208 times)
Offline Lakeview
« on: November 23, 2023, 04:07:31 PM »
Found this distributor in my garage can't find any information on what it's from. Any help would be appreciated.  C5AF-12127 BG. The BG is what I can?t determine.
« Last Edit: November 23, 2023, 09:57:39 PM by J_Speegle »
Re: Distributor Decode Help
« Reply #1 on: November 23, 2023, 06:22:42 PM »
Is there a date code marked under the "suspicious" Fprd Part number?
Offline Lakeview
« Reply #2 on: November 23, 2023, 08:17:47 PM »
Yes it is 5LB
« Reply #3 on: November 23, 2023, 09:35:47 PM »
Found this distributor in my garage can?t find any information on what it?s from. Any help would be appreciated.  C5AF-12127 BG. The BG is what I can?t determine.
Did you try and look it up in one of the MPC versions? At the start of that section there will be the identification numbers/letters listed an what they carried in stock when the MPC was written - Often a different distributor to reduce the need to stock the hundreds of different units going forward
By 1969 it had been replaced in the service line with C4AZ-12127-M
Looks like one of the applications was a full bodied 1966 Ford with a 352 cu engine 4V and automatic without Thermactor
Did not find another application in either a 68 or 69 MPC
« Last Edit: November 23, 2023, 10:06:49 PM by J_Speegle »
Offline Lakeview
« Reply #4 on: November 23, 2023, 09:46:46 PM »
It is a duel point Distributer
« Reply #5 on: November 23, 2023, 09:52:30 PM »
It is a dual point Distributer
With a vacuum advance boss and hole in the housing?
Just as a note - Dual point conversion and point plates have been available since the 60's
Can you confirm that it is a big block distributor?
« Last Edit: November 24, 2023, 09:39:45 AM by carlite65 »
Offline Lakeview
« Reply #6 on: November 24, 2023, 11:57:15 PM »
It is a big block with vacuum advance.
« Reply #7 on: November 25, 2023, 01:31:38 AM »
That would match the 66 application mentioned above
