Author Topic: 67 Shelby/Mustang Horn Wiring Question  (Read 914 times)
Offline davekelly
« on: November 14, 2023, 08:43:51 PM »
Quick question on 1967 Shelby horns. My car has had its horn jumper wiring hacked into and it looks like each horn is connected into the main harness running across the bottom of the front radiator support with just a single wire connecting to each horn. Is this correct? I'm troubleshooting the infamous "no horn" problem and wanted to start at the horns and run back. They blow with a direct connection to battery positive post and horn grounded to support and thus grounded.  I do have one stray black wire that was cut at the far end of the main harness on passenger side just hanging out there connected to nothing. Any idea what this wire may be for?
thanks
« Last Edit: November 15, 2023, 02:29:43 PM by J_Speegle »
Re: 67 Shelby Horn Wiring
« Reply #1 on: November 14, 2023, 09:19:19 PM »
If the wiring for the horns are the same as the standard Mustang, the horns are daisy-chained; i.e. the left most horn has 2 wires going to the female spade lead.  The ground for the horns is the chassis itself.
Offline davekelly
« Reply #2 on: November 14, 2023, 09:25:47 PM »
thank you Midlife- Yes, I believe the horn jumpers are the same as a 67 Mustang and if I understand you correctly the left most horn being the passenger side horn should have two wires?  I will guess that the short cut wire I described below is the second wire you referenced.
Offline kkupec02
« Reply #3 on: November 14, 2023, 09:28:57 PM »
welcome to the forum
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
Offline kkupec02
« Reply #4 on: November 14, 2023, 09:29:23 PM »
new Shelby owner?
« Reply #5 on: November 14, 2023, 09:35:05 PM »
The 67 Shelby horn wiring is identical to the Mustang .
« Last Edit: November 14, 2023, 09:40:47 PM by Bob Gaines »
Offline davekelly
« Reply #6 on: November 14, 2023, 10:36:29 PM »
thanks to all for the help.
« Reply #7 on: November 14, 2023, 11:51:19 PM »
Left side is driver's side.
