Author Topic: 67 Shelby headlight bucket assembly  (Read 4243 times)
« on: November 04, 2023, 11:53:36 AM »
A friend of mine is parting out a 1960 Starliner, and someone told him that the headlight buckets are the same as the 67 Shelby.  My initial thought was "no way", because the 60 has four headlights.  My other thought is that for the Shelby headlight, why would it need to be any different than the Mustang for that year.  Perhaps the 67 Shelby fog lamp uses it?  I don't have the 67 Shelby assembly manual, and don't want to buy one just for this.  Can someone shed some pun-intended light on this?  Part numbers appreciated.  TIA
Re: 67 Shelby headlight bucket assembly
« Reply #1 on: November 04, 2023, 12:14:41 PM »
A 67 Shelby has 4 headlights not two.Various 4 light headlight buckets can be used once striped of various other application riveted on brackets.
« Last Edit: November 04, 2023, 12:20:11 PM by Bob Gaines »
« Reply #2 on: November 04, 2023, 02:56:45 PM »
As Bob mentioned, the 67 Shelby uses 4 buckets, all of them the 5 1/2 size.
It also does not have foglights.
The headlights in the grill are high beam only (2 prong).
The outboard headlights (outside of the grill) are high/low beam (3 prong).
You can be led astray because the later Shelbys have a chrome bezel around the headlight which make them look larger.
s/lead/led/
« Last Edit: November 04, 2023, 06:51:39 PM by Bossbill »
Offline rustbucket
« Reply #3 on: September 28, 2024, 09:54:08 PM »
the 4 shelby headlight buckets (or bowls like i like to call them) i believe originated from the early galaxie if im not mistaken
« Reply #4 on: September 28, 2024, 10:14:58 PM »
There were more then one application that they could possibly be used from.
