Author Topic: Attaching the steering column lower trim panel  (Read 2547 times)
Offline RocketScientist
« on: October 29, 2023, 10:04:42 PM »
I was wondering how the plastic lower trim panel, that sits between the steering column and the dash panel, is installed? Are there any bolts that go through the slot in the panel to support it - as I think I'm missing something. The Car is a Dearborn Nov 14 1969 build.
Thanks, Brad
Offline hopey
Re: Attaching the steering column lower trim panel
« Reply #1 on: October 29, 2023, 11:05:12 PM »
This one? If so no just the two screws that hold it onto the lower dash edge.
1970 BOSS 302
Built 11/15/69 Dearborn
« Reply #2 on: October 30, 2023, 02:15:26 AM »
Yes its that one and thanks for confirming its just the two screws.
« Reply #3 on: October 30, 2023, 04:22:05 AM »
Isn't there the clips also on the back side to keep it tight to the dash along with the two lower screws with the large integrated washer heads like in the prior year?
« Reply #4 on: October 30, 2023, 08:27:56 AM »
You are correct Jeff and I have been able to get a pic of the bracket that intrigues me. It comes of a March 1970, Metuchen Boss and possibly a later production line addition?
« Reply #6 on: October 30, 2023, 09:16:47 PM »
No, it's not the collar retainer but the one circled below it.  :)
Offline sah62
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
« Reply #8 on: November 02, 2023, 03:54:13 AM »
I think you're right and this car must have a saggy panel and someone gave it some extra support. The confusion is that it has been done so well, that it looks normal.
Offline HDAshmore
« Reply #9 on: November 08, 2023, 11:32:48 AM »
The clip in question?
Dan in Kansas
« Reply #10 on: November 08, 2023, 01:48:11 PM »
Slightly off topic, but the two "tangs" on each side of the metal clip are very similar to the type of retaining method  that heater control knobs use.
