The plastic version is the one that originally was on my car and broke... because it's plastic. I replaced it with another plastic one, I'm assuming from NPD.
Yes I do believe that's correct. I'll have to look at my car tomorrow but I seem to recall it was a little fiddley to get it in position.
Photos of the steering column nuts would be great as well if you could. Thanks appreciate it
I know this is a bit off topic for this thread but here you go. Not sure it's the best picture of the nuts your questioning.
Clip for the all plastic constructed air vent cable.
Nut for the improved partial steel shafted air vent cable.
That is great thanks Dave that clarifies my question on the column nuts. Also noticed that the air vent bracket sits in-between the the parking brake handle bracket and the dash. I may need to trouble you for a few more photos. I will PM you if it is not too much trouble. Thank you
As a matter of fact the vent bracket sits on top of the openings in the hand brake bracket and uses the two screws to secure both giving the perception the vent bracket is separate when it is not.
forgot about the Fog Light knob as well. I don't recall mine, but I took the car apart 5 years ago. Will have to try to find it.
