Author Topic: 68 SJ 390 Waterpump Bypass Hose  (Read 554 times)
Offline bullitt68
« on: October 25, 2023, 05:07:38 PM »
Trying to determine what I should be using for the Waterpump Bypass Hose. See this from Dead Nuts On
« Last Edit: October 25, 2023, 05:33:19 PM by bullitt68 »
Mike
Re: 68 SJ 390 Waterpump Bypass Hose
« Reply #1 on: October 25, 2023, 05:40:56 PM »
The picture is of the metal tube that is pressed into the pump and into the intake. Ford used a special reinforced rubber hose to go between the metal nipple in the intake and the one coming out of the water pump. most people use a piece of heater hose but it is thicker wall and has a tendency to balloon out . I would check with jacks as I think he was selling a short reinforced hose alternative.
Offline bullitt68
« Reply #2 on: October 25, 2023, 05:54:38 PM »
Great thanks I sent him a message
Mike
Offline bullitt68
« Reply #3 on: October 25, 2023, 06:14:01 PM »
I have tried searching to find a photo of an original, but no luck so far
Mike
« Reply #4 on: October 25, 2023, 06:54:44 PM »
It is a slightly thinner wall (although reinforced)then regular heater hose . Some had ribs and some didn't. It is painted with the engine so markings are irrelevant .  You could also try Mansfield Mustang .
Offline CandyAppleRed
« Reply #5 on: October 28, 2023, 04:24:24 AM »
part number C2OZ-8597-D
you might found some on eBay.
Laurent
« Last Edit: October 28, 2023, 11:10:29 AM by CandyAppleRed »
1967 Fastback 390 GTA Dearborn May 67 7F02S201072 (stolen)
1967 Fastback 390 GT San Jose Nov 66
Offline bullitt68
« Reply #8 on: October 28, 2023, 05:47:35 PM »
Laurent
Great thanks
Mike
