Author Topic: Lower Control Arm Pivot Bolts  (Read 3800 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: May 06, 2011, 12:33:39 PM »
Do we have any pictures that show 1966 lower control arms originally installed with the nuts on the pivot bolts, facing the rear?
I know they are suppose to face the front but the evidence on the faces of the attachment brackets of the shock towers indicate
mine were put on backwards at Ford.
(i.e. the nut flanges left scratches in the metal that are larger in diameter than a bolt head would leave.)
66 Metuch Conv
Nightmist, Std Blu Int
Re: Lower Control Arm Pivot Bolts
« Reply #1 on: May 06, 2011, 10:40:15 PM »
The nut should go to the front.  If I remember right, there was a lock washer used behind the nut, so you should be able to determine what way it was installed.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: May 07, 2011, 07:40:47 AM »
Thanks Charles....Back out with the 10x magnifying glass.
66 Metuch Conv
Offline aaatp
« Reply #3 on: May 07, 2011, 11:12:26 PM »
For what it is worth, the pivot bolts on my 66 Dearborn convertible were, like yours Bryan, put in with the nuts at the back. My shop manual does not have a good reference to verify this, but if you go here, http://www.hotrodreference.com/928/1964-1966-ford-mustang-front-suspension-exploded-diagram/ the diagram shows the nuts also at the back. I am also curious to know what was the standard placement to make sure I get it right. My car appears to have had the original lower control arms installed.
Thanks: John
« Reply #4 on: May 07, 2011, 11:21:11 PM »
The diagram is not a Mustang front suspension.  You can put them on however you want, but the norm is with the nut in front.
« Reply #5 on: May 07, 2011, 11:31:10 PM »
+1 . photo from 1965 .Bob
Offline aaatp
« Reply #6 on: May 07, 2011, 11:47:08 PM »
Charles and Bob, That was quick, Thanks, looks like I'm going to have to turn mine around.
Offline JKWilson
« Reply #7 on: May 08, 2011, 12:47:07 PM »
Shelby American assembly line photo Bob?
« Reply #8 on: May 08, 2011, 07:49:29 PM »
Yes I'm sure it is - Bob doesn't have allot of 66 NJ plant pictures  ;)
But neither do I LOL but we're trying
