Author Topic: 1969 Hood Black Out / Stripes  (Read 8128 times)
Offline Aussiemach
  • Silver Level Subscriber
« on: May 05, 2011, 11:45:01 AM »
Is the following guide for the hood black out and stripes correct for my Mach1 ?
(thanks Armond copy & paste saves retyping!)
"The correct numbers are 7/16" between the main black out and the outer pin stripe and this stripe is 1/8" As far as the distance between the hood edge and the outer stripe, it was inconsistant and I have seen it either a touch to the left or right. It was laid up with a jig and if it was not centered perfect it would be off. To center the stripe exactly according to the measurements of the two original paint hoods I have, the main black out from the edge of the hood to the edge of the main black out is 1 3/16" The outer pin stripe then 7/16" of an inch from the black out, then it will be correctly centered. Also as a important note, at the front of the hood. If you measure from where the turn straightens out, the outer stripe is 2 3/16" from the edge of the hood. This point should be at just abouit the 3" mark from the OUTSIDE EDGE of the hood. This measurement from this point to the point of the center of the hood at the nose, the distance there needs to change 3/8" of an inch closer to the edge of the hood. If you don't and put this equal along the edge, it is an optical illusion and it makes it appear that at this point the black out is too short. I hope this makes sence! It seems drastic but if you don't it will look strange! I hope this helps and was not to confusing. Good luck!"
Also the 1/8" stripe has a gap of approx 1/4" between the end of the stripe and the edge of the hood and cowl.
« Last Edit: May 12, 2011, 12:06:38 PM by Aussiemach »
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
Offline Aussiemach
Re: 1969 Hood Black Out / Stripes
« Reply #1 on: May 08, 2011, 12:17:54 AM »
Another Question;
Are the 1/8" pin stripes parallel with the edges of the hood ?
At what point does the pin stripe start to curve away from the edge of the hood ?
Would this point be about 3 3/4" back from the front edge of the hood ?
« Last Edit: May 08, 2011, 01:37:28 AM by Aussiemach »
Re: 1969 Hood Black Out / Stripes ( added 2 questions )
« Reply #2 on: May 08, 2011, 07:54:21 PM »
Never really measured it all (used the template the last time I did it) and don't have an original tape/black out hood at home to measure for you.   Sorry
Just noticed that your a firefighter - stay safe ;)
Offline Aussiemach
« Reply #3 on: May 09, 2011, 05:43:47 AM »
Thanks anyway Jeff. Went to see the spray painter today and discussed the black out. The guide from Armond seems to make sense so that's what we are going with.
« Reply #4 on: May 10, 2011, 09:13:55 PM »
Sure it will work out just fine.
Did you find a paint your happy with, for the black out?
Offline Aussiemach
« Reply #5 on: May 10, 2011, 09:24:21 PM »
Will let you know. None of the USA PPG or other brands cross reference out here, so all paint so far has been mixed using bit's of original paint on the body and info from this site.
The black out paint has been a real pain so far @#$%^&. I think we are on to the right one now.
« Reply #6 on: May 10, 2011, 11:01:08 PM »
Real nice drawing of the hood black out, including the radius, on the Boss 302 site.  Brian
Offline Aussiemach
« Reply #7 on: May 11, 2011, 10:20:41 AM »
Thanks Brian.
Offline Aussiemach
« Reply #8 on: May 12, 2011, 12:07:52 PM »
Progress yesterday
