Author Topic: Water pump  (Read 1047 times)
Offline Mustang64
Water pump
« on: August 30, 2023, 07:23:08 AM »
Hi everyone,
I had a little leakage on my 64 1/2 water pump, so I decided to dismantle and change the gasket.
I noticed one bolt was missing out of 9, that could explain the leakage.
I noticed also the the outlet on passenger side, towards the cylinders block was fully tapped with white sediments (look like salt). I cleaned everything but I'm wondering :
- how it could worked like this
- why it was tapped on passenger side and not on driver side
taking into account that on my 2 years ownership I always used the correct coolant (yellow/green colour)
Any answer will be the most welcome
Have a good day
Didier
Re: Water pump
« Reply #1 on: August 30, 2023, 06:53:04 PM »
To help everyone, which engine are you working with? U, D, C.........?
« Last Edit: August 30, 2023, 10:27:15 PM by J_Speegle »
Offline Mustang64
Re: Water pump
« Reply #2 on: September 01, 2023, 04:28:47 AM »
Sorry, it's a V8 code D
Re: Water pump
« Reply #3 on: September 01, 2023, 12:58:07 PM »
I assume it's the "deep cover."
Using the pic below, which hole?
Offline Mustang64
Re: Water pump
« Reply #4 on: September 01, 2023, 01:36:55 PM »
The one on top of your picture
Re: Water pump
« Reply #5 on: September 01, 2023, 03:15:15 PM »
Consider a replacement kit from AMK products https://www.amkproducts.com/ Look up kit - F-487. It's for a 289 with an aluminum pump, no A/C (a different kit is used for A/C) consisting of 9 bolts - $25.00. Knowing how time is the enemy, it is not surprising of the residue you found. Because of your location, shipping might be a problem. Check with them.
I've used the AMK kits on several of my 65-66 Mustang projects and am satisfied.
Re: Water pump
« Reply #6 on: September 01, 2023, 03:39:13 PM »
It is tapped on the  driver's side and the tapped hole goes all the way into the block. From best to worst.
- The previous owner left the bolt out.
- You might have a bunch of junk in the tapped hole (corrosion).
- The bolt broke off inside of the timing cover bolt "tunnel". When corroded the bolt likes to break an inch or so from where it screws into the block.
- The bolt broke even with the block surface.
Offline Mustang64
Re: Water pump
« Reply #7 on: September 02, 2023, 09:57:11 AM »
Hi everyone,
Thanks for your answers
jwc66k,
Digging in my own reserve of bolts, I was able to find the correct one, so no worries
You are right : time is the enemy. This car have been stored in a garage in southern California from 2010 to 2020. Then sold and shipped to France but didn't move much up to dec, 2021 when I bought it. I had the relevant problems : change of seals, gaskets, hoses...
Bossbill,
There isn't broken bolt, just a missing one which explains the leakage and the sediment deposit
Indeed there is corrosion inside
I was thinking of using a radiator cleaner from Bardahl to clean the whole cooling system ; what do you think ?
Have a good day,
Didier
