Author Topic: 1969 B2 Starter Part #  (Read 4786 times)
Offline Gcodecowboy
« on: August 29, 2023, 09:19:12 PM »
Is this the correct starter for a 69 Boss 302?
C9AF-11001-B
Thank you,
Mike
06/27/1969 Boss 302
Re: 1969 B2 Starter Part #
« Reply #1 on: August 29, 2023, 09:59:10 PM »
C9AF-11001-B
Thank you,
Mike
C9AF-11001-B is for a 302 or 351W auto.  C9AF -11001-F C7AF-11001-F is for 4 speed.
« Last Edit: August 30, 2023, 01:50:36 AM by Bob Gaines »
Offline Gcodecowboy
« Reply #2 on: August 29, 2023, 11:08:21 PM »
C9AF-11001-B is for a 302 or 351W auto.  C9AF -11001-F is for 4 speed.
Thank you Bob. That is exactly the information that I am looking for.
Mike
06/27/1969 Boss 302
Offline hopey
« Reply #3 on: August 29, 2023, 11:37:21 PM »
Mike
The 1969 BOSS 302 starter is C7AF-11001-F.
The 1970 BOSS 302 starter is D0AF-11001-C
1970 BOSS 302
Built 11/15/69 Dearborn
« Reply #4 on: August 30, 2023, 01:47:13 AM »
Thanks for catching my typo .Yes I meant to write C7AF-11001-F for the 68/69 4 speed 302 including Boss and 351W.
« Reply #5 on: August 30, 2023, 01:55:52 AM »
You will find 30 C9AF-11001-B or more marked starter cases to every 1 marked C7AF-11001-F. Keep in mind that most original starters have been rebuilt at least once by now. Rebuilders did not care or pay attention to what was marked on the case so you may find the correct marked 302 4 speed case but it may be built around a FE 3 ear nose cone etc.
Offline hopey
« Reply #6 on: August 30, 2023, 12:25:04 PM »
Bob that is true for most used and remanufactured parts, it is the difference between what fits and what is correct. Finding a D0AF-C for my 70 was certainly a challenge, I purchased several old starters to get all the correct pieces to assemble a working original.
1970 BOSS 302
« Reply #7 on: August 30, 2023, 12:55:19 PM »
The unique 4 speed nose cone that was used starting in 68 is the second hardest piece to find after the correct marked case. I pick them up whenever I see a core with one.
« Reply #8 on: August 30, 2023, 01:31:14 PM »
I seem to recall that the block plate opening and nose diameter where it fits into the plate were a different size than earlier starter noses.
Do we have the diameter of the nose where it fit into the blockplate opening?
« Reply #9 on: August 30, 2023, 01:45:54 PM »
Not a problem if you use the correct 68 and up block plate and bellhousing with the correct 68 and up 164 flywheel.
« Reply #10 on: August 30, 2023, 03:56:19 PM »
I was side stepping the question because I am away from my parts to measure. Maybe someone else can measure.
Offline hopey
« Reply #11 on: August 30, 2023, 10:50:14 PM »
Not sure about the diameter, I have never really noticed a difference. I would measure but I am in the middle of final preparations & cleaning my BOSS for next weeks MCA Grand National. What I do know is that getting the correct depth so you engage the ring gear fully, there is a long nose (2-3/8 inch effective depth if my memory is correct) and a shorter 2inch .  As Bob states they are often mixed up and if you see a 4speed MT long nose 164tooth starter at a swap meet, grab it!
1970 BOSS 302
Offline Gcodecowboy
« Reply #12 on: December 15, 2023, 01:34:23 PM »
What should the part number be on the nose cone of a C7AF-11001-F starter?
06/27/1969 Boss 302
