Author Topic: 69 428 CJ power steering pump  (Read 1022 times)
Offline 1969 Cale II
« on: August 22, 2023, 08:56:19 AM »
69 428 CJ, are the pump and brackets special or common FE parts? This car is missing it all
Re: 69 428 CJ power steering pump
« Reply #1 on: August 22, 2023, 09:54:50 AM »
Typically common to FE however the sheet metal backside portion of the P/S pump that is held on with a O ring varies depending on application.
« Reply #2 on: August 23, 2023, 06:19:29 PM »
For a special car like that you want the right stuff date coded to match the build date of the specific car. I would start by getting the Marti Report so you know the exact date the car was built. Then give Dan at Chockostang a call. He will likely have everything you need.
The power steering pump tag is specific to the date and pump. The reservoir is specific to the application. The aluminum bracket can be date coded depending on the brand.
