Author Topic: 67 AC comp clutch wire 19A885 color  (Read 951 times)
« on: August 17, 2023, 09:59:08 PM »
For a 67 AC compressor clutch wire 19A885, all I can ever recall seeing is black insulation, and the NPD repro is black as well.  The schematic calls for wire 348 in "green".
I recall seeing the 348 green wire extending through the firewall a couple inches, and then a single wire extension in black connecting to the wire that is attached to the brushes.
So is black appropriate or should I be looking for green?  Thanks, John
Re: 67 AC comp clutch wire 19A885 color
« Reply #1 on: August 17, 2023, 11:02:09 PM »
John I have never seen a green one. Regardless of assembly plant they all have been black.
« Reply #2 on: August 17, 2023, 11:34:14 PM »
+1 what he said.
« Reply #3 on: August 18, 2023, 07:50:28 AM »
Thanks - that confirms what I've seen.
« Reply #4 on: August 18, 2023, 09:08:31 AM »
May be Ford thought the green wire stood out and looked bad on the engine? Who knows.
« Reply #5 on: August 18, 2023, 11:47:10 AM »
This was not a isolated incident as the extension wires were the same colors for wires used on 68,69 and 70 too.
« Reply #6 on: August 18, 2023, 06:24:35 PM »
It's a typo. The wire is green under the instrument panel. It becomes black at the firewall. The manuals are not perfect. Very good but like anything made by humans, not perfect.
