Author Topic: 1985 Mustang GT  (Read 4996 times)
Offline BOSSHiPo
1985 Mustang GT
« on: August 15, 2023, 01:24:25 PM »
I inherited my late Uncles all original 85 GT 5 speed Mustang
I'm trying to figure out if the Holley carburetor is original to the car from Ford.
How is the best way to determine this?
Thanks for the help!
Re: 1985 Mustang GT
« Reply #1 on: August 15, 2023, 02:14:32 PM »
Should be date coded like other Holley's.  What's the stamping on the air horn and is there a tag?
Offline BOSSHiPo
Re: 1985 Mustang GT
« Reply #2 on: August 15, 2023, 02:38:25 PM »
Charles
I actually have 2 one on the car and one in a Holley box
I'm not sure about the details, my uncle passed away so no one to ask
Here is what I have so far
stamped on air horn
E4ZE-9510-3A
List-50151
3003
I'm trying to determine the car is in fact 100% original
It only has 386 miles, he bought it new and it's been in his garage since then
Thank you for the help!
Re: 1985 Mustang GT
« Reply #3 on: August 15, 2023, 02:45:16 PM »
3003 would decode to 300th day, presumably 1983.
Offline BOSSHiPo
Re: 1985 Mustang GT
« Reply #4 on: August 15, 2023, 03:35:43 PM »
Great!
Thank you that helps!
I'll check the one on the car when I can. Hoping it's the original one still on the car
Thanx!
Offline 70b302cat
Re: 1985 Mustang GT
« Reply #5 on: August 16, 2023, 10:49:55 PM »
Your boxed carb is definitely too early.  Most 1985 5.0 5 speed Mustangs had a E5ZE-9510-GA for a carb with a list of 50265.  There has reportedly been early build cars that have had a E4ZE.  When you pull the air cleaner to check the air horn information, there should also be a blue tag on the carb with data on it.
Post both the blue tag information (if still there) as well as the air horn information, and we can probably decode it for you.  Also please post the vehicle's build date (MM/YY) from the upper right corner of the Vehicle Certification Label on the driver's door jamb.
« Last Edit: August 16, 2023, 10:59:28 PM by 70b302cat »
Offline BOSSHiPo
Re: 1985 Mustang GT
« Reply #6 on: August 17, 2023, 07:52:30 AM »
Thanks guys!
Will do when I see the car again next month it gives me something to look for.
I'm learning all I can, appreciate it!
Offline kr3760
Re: 1985 Mustang GT
« Reply #7 on: August 21, 2023, 09:05:27 AM »
Sounds like a great car.  Selling?
Offline BOSSHiPo
Re: 1985 Mustang GT
« Reply #8 on: August 21, 2023, 10:40:38 AM »
Thank you!
Not at this time.
When I get it home, most likely give it a really good detail and then would like to take it to a couple of MCA shows!
