Author Topic: glass  (Read 931 times)
Offline cob428
glass
« on: August 15, 2023, 11:32:35 AM »
Did the windshield or back glass come with a weatherstrip or rubber of some sort around the edge of the glass?
Concourse Wantabe
69 GT 500 Built Dearborn 06/69
A/C, Auto,
69 Mach 1 Metuchen 11/68
A/C, Auto 351 W
2009 Supersnake
Offline preaction
Re: glass
« Reply #1 on: August 15, 2023, 11:40:29 AM »
Both used a weatherstrip to hold in place and weather seal the glass.
Offline 69GT350H
Re: glass
« Reply #2 on: August 15, 2023, 12:46:06 PM »
Re: glass
« Reply #3 on: August 15, 2023, 05:49:52 PM »
The rear glass uses a gasket, the front does not, but uses a bead of window sealer on the body that the glass is then laid into.
+1
Have used the premade coil of adhesive with the embedded wire years ago That was great stuff though on hot days was a pain to cut/remove since the stuff was so goo it would reseal itself as you cut through it. Unlike with new cars where the windshield is part of the body construction and strength factoring I won't use anything that sets up fully. Like my windshield and rear window to have the ability to move slightly if need be. Just my choice
3M makes a similar cord still - https://www.cjponyparts.com/windshield-ribbon-sealer-mustang-1969-1973/p/AD8612/
Others like 3M? Auto Bedding and Glazing Compound
