Author Topic: 67 Fender changes : -A vs. -B  (Read 1133 times)
« on: August 04, 2023, 08:01:47 PM »
According to the 68 MPC there was a change in the 67 fender part number revision letter from -A to -B. The service part numbers are C7ZZ-16005-A RH (and 16006 LH) "Before 12/1/66" and C7ZZ-16005-B RH (and 16006 LH) "From 12/1/66."
This may be a running change item.
However, do know what is at the heart of the change?
Update subject to change hyphen to colon.
« Last Edit: August 05, 2023, 10:52:36 AM by Bossbill »
Re: 67 Fender changes -- -A vs. -B
« Reply #1 on: August 04, 2023, 08:46:54 PM »
Fender rubbing issues. I believe the change was in the flaring of the opening. Wheel opening moldings also updated at the same time. I believe Jeff shared a service bulletin on the subject several years ago..
Re: 67 Fender changes : -A vs. -B
« Reply #2 on: August 05, 2023, 10:51:27 AM »
Ah, so two running changes. Fender and trim.
I gather this would affect all plants.
« Reply #3 on: August 05, 2023, 11:41:53 AM »
Yes, Fenders and trim were stamped and processed at other facilities.  If I recall the major sheet metal stamping operations were in Woodhaven (Michigan, still there), the Cleveland Ohio area, and Buffalo New York.  I'm not sure about molding operations though.
« Reply #4 on: August 06, 2023, 05:59:59 PM »
Thread related to the problem or issue with the "new" wide oval tires
https://www.concoursmustang.com/forum/index.php?topic=16529.msg103485#msg103485
