Author Topic: Replacing the VIN plate rivets?  (Read 2826 times)
Offline HIPO-1965
« on: April 28, 2011, 07:45:41 PM »
Hi Everyone,
I'm in the process of restoring my 65' Fastback and was wondering how I should go about remove/replacing my current VIN door tag?
1. What size drill bit should I use to remove the OE rivets?
2. How do I punch the 'new' rivet's back in without damaging them?
Your feedback would be greatly appreciated...
Cheers,
HIPO-1965 8)
« Last Edit: April 28, 2011, 07:58:42 PM by HIPO-1965 »
Re: Replacing the VIN plate rivets?
« Reply #1 on: April 28, 2011, 10:06:59 PM »
Use a drill slightly smaller than the indentation for removal.  To install, I believe the size is 1/4" drill bit (reversed so the shank is inserted into the indentation), and give a couple good love taps which expands the rivet.  If 1/4" is not correct, use a drill bit that just barely fits into the indentation.  That's it!
Offline HIPO-1965
« Reply #2 on: April 28, 2011, 11:51:49 PM »
Hi midlife,
Thanks for the early response and it's greatly appreciated...
Cheers,
HIPO-1965 8)
