Author Topic: C6 Shift Linkage Adjustment  (Read 2042 times)
Offline snikliw87
« on: July 16, 2023, 10:25:50 PM »
Hi all,
Does anyone have any advice on the best way to line up a C6 transmission's shift linkage to the interior automatic floor shifter?  I tried following the manual which describes loosening the nut and placing the shifter in neutral and the transmission in neutral and tightening the nut- only problem is it doesn't line up when manually shifting into first gear.  I tried centering it on Drive but it seems to be "in between" on some of the gears still.
1967 Fastback GTA 390 - Built 10/1966 San Jose
Re: C6 Shift Linkage Adjustment
« Reply #1 on: July 17, 2023, 06:40:32 AM »
Do you have a console?
Offline snikliw87
« Reply #2 on: July 17, 2023, 10:13:13 PM »
No console.
« Reply #3 on: July 18, 2023, 05:52:52 AM »
You either have something wrong with the shifter itself or the incorrect  lever in the transmission case.
I'll assume the bushings are tight and a visual inspection of the shifter assembly is good, leaving the more probable suspect of the incorrect lever in the transmission.
Pictures of these areas might help.
« Reply #4 on: July 18, 2023, 11:15:22 AM »
Yes the shifter lever in a floor shift application on a C6 is different then a column shift . I would suspect this if the trans is newly acquired . The  FE C6 are overwhelmingly more common with the column shift lever then the floor shift by about 10 to 1   The lever has been reproed and is available. Find a picture on WWC or ebay and compare. Or it may be a wrong transmission to shifter arm. It is common place for a shifter arm to get misplaced when a car is apart. The C6 arm is unique and hard to find compared to the plentiful C4 arm. I would suspect this if you are putting the car together that has been apart for a while. Of course if the car has been together with all the same parts and worked then the problem now is more likely some kind of adjustment.
Offline snikliw87
« Reply #5 on: July 18, 2023, 06:52:02 PM »
The transmission shifted fine in every gear before our partial restoration so I am confident we have the correct rod for the C6 GTA.
What I am not confident on is if we have the correct washers/bushings for each side of the rod connecting to the shifter and the transmission arm.  There is a wobble in the rod on the shifter attachment side which is concerning.
See attached photos (taken from the ground looking up).
