Author Topic: 69 Boss 302 Power Steering  (Read 7144 times)
Offline chockostang
« on: June 22, 2023, 08:27:17 PM »
Thank You for that,  This has a BK pump (return points at the ground), so i'm sure it was not correct as the return from cooler has to make serious bends to attach to pump.
If I'm correct, the same pump end pressure will be same as 351W for 69.  C7AA Aluminum cradle, Non hole flat steel, and the BK style indexing bracket???
Offline hopey
Re: 69 Boss 302 Power Steering
« Reply #1 on: June 22, 2023, 10:10:24 PM »
I believe so.
I have a BK pump here as well as an original 69 cooler. Just looking at them I do not see how the return hose would work especially with the long leg of the 69 cooler vs the 70 style.
1970 BOSS 302
Built 11/15/69 Dearborn
Offline chockostang
« Reply #2 on: June 23, 2023, 09:29:16 AM »
That is what this has.  A BK pump which means the cooler hose has to attach to the down pointing return on the pump, make a 180 turn to get to the cooler.  Seems odd.
The manual says BF pump (return nearly straight back of pump).   So is your pump and this pump wrong as they are are BK, and not BF?
Did the 69 B2 have both?
Offline Mike Bauman
« Reply #3 on: June 23, 2023, 11:51:39 AM »
1969 Boss 302 pressure hose at back of pump is a VERY hard to find piece! I have only seen 2 nos loose in over 35 years playing with mustangs. I have attached a photo
Offline Mike Bauman
« Reply #4 on: June 23, 2023, 12:10:34 PM »
More photos
Offline chockostang
« Reply #5 on: June 23, 2023, 06:56:40 PM »
So Hopey has A BK pump, you have a BK, this one I'm rebuilding is a BK, then it stands to reason they all were BK's as the 351W had.
The literature in the above document must be incorrect as it states a BF pump.
Who wrote this document?  FORD MPC --who is MPC?
« Reply #6 on: June 23, 2023, 06:58:36 PM »
MPC---master parts catalog. written by engineers who never actually worked on the cars they designed.
Offline chockostang
« Reply #7 on: June 23, 2023, 07:28:10 PM »
Well that damn sure explains it.
As most know I have stated it was the 60's, we lived it,  the 60's were happy times, free thinking, free love, a free use for some of the mind altering things that were available.
I think most, a good many of the Ford engineers were free thinker that use LSD. SOMETHING had to make them do the many stupid things, changes they did.
Offline chockostang
« Reply #8 on: June 23, 2023, 07:32:24 PM »
Thank You Mike for pictures, very informative.
Dan
Offline chockostang
« Reply #9 on: June 23, 2023, 07:33:23 PM »
I believe so.
Thank You Hopey for info, pictures.
Dan
« Reply #10 on: June 23, 2023, 09:42:09 PM »
And list parts currently (at the time of printing) available that could be used to service Ford vehicles
« Reply #11 on: June 24, 2023, 01:18:25 AM »
Actually, no. It was written by clerks based on a lot of input from design engineers, sometime conflicting, well after the design were released for production, as design engineers were busy on the next years' production. Labeled "For Car Parts", but called in slang the " MPC", it was published roughly at the time of the introduction of the first vehicles of that model year to dealers and that was intended to be used by those dealers' service departments. Assembly line engineers also gave their initial input, and, as we have seen, made changes as the production year went on. There were new product prototypes made for publicity, Ford Marketing too - and remember, the Mustang was initially called the "Special Falcon". I have seen pictures of what is obvious to us, a Mustang, but labeled as a "Cougar".
Offline chockostang
« Reply #12 on: June 24, 2023, 06:44:51 PM »
Here are pictures of the 69 B2 Pump end pressure.
Part number C9ZA 3A719 D,  yes D.
Offline chockostang
« Reply #13 on: June 24, 2023, 06:48:31 PM »
 C9ZA 3A719 D
Offline chockostang
« Reply #14 on: June 24, 2023, 06:53:05 PM »
Same hose of original 69.  I can only post one picture at a time??
