Author Topic: six cylinder neg cable routing  (Read 6872 times)
Offline 66GTCoupe
« on: April 26, 2011, 12:10:37 AM »
Help,  I can't seem to find out were the negative battery cable attaches to on my six coupe.  any help would be appreciated.
Re: six cylinder neg cable routing
« Reply #1 on: April 26, 2011, 08:16:23 PM »
When and where was it built?  In case it makes a difference ;)
Offline Twilight65
  • Gold Level Subscriber
« Reply #2 on: April 26, 2011, 10:19:21 PM »
On my Dearborn 66 vert ,it goes to a stud on the engine block below the alternator.
Dave
Offline 66GTCoupe
« Reply #3 on: April 26, 2011, 10:26:09 PM »
its a dec 65 dearborn convertible.  thanks so far for the info any pictures? of what the stud looks like?
Offline Twilight65
« Reply #4 on: April 27, 2011, 12:14:50 AM »
Here's a pic at the block.
Dave
Offline NEFaurora
« Reply #5 on: April 27, 2011, 10:01:10 PM »
While we are on the subject, Anyone know if the special stud/nut/bolt is reproed?
Luckily I still have my original, but would like a spare..
Tony K.
MCA#70001
Offline Twilight65
« Reply #6 on: April 27, 2011, 11:08:08 PM »
Here's a picture of the actual stud off my 66. 1 9/16" long, 3/8-16 block side, 7/16-14 connection side.
Dave
Offline 66GTCoupe
« Reply #7 on: April 30, 2011, 05:59:28 PM »
thanks, that helped me out alot, now I just have to get one made
Offline sparky65
« Reply #8 on: June 06, 2012, 10:22:07 PM »
Did you end up making one?  I am curious because I am starting to look into getting one made.  I would need a few more dimensions on the length of the threaded sections.
Steve
2009 Black GT Coupe
Offline 66silverblue
« Reply #9 on: June 10, 2012, 01:55:56 PM »
Also a bit off subject but the black clamp that holds the cooler lines together below that? where can I get one of those. I have many parts engines and that ground bolt and clamps are missin off everyone . Also the clamp that holds the lines together on the pass side where it straps  on the valve cover.
« Reply #10 on: June 10, 2012, 04:14:19 PM »
Dave
This is one of those poorly documented (from a restoration standpoint) areas. It involved three different Ford engineering groups, engine, automatic transmission and electrical, and they didn't communicate well.
The stud is not shown in any of the Mustang Assembly Manuals but is shown in the Ford Car Parts Illustration Section A71, page 6, as part number 380818-S, and it is indicated as "not serviced". The part number is not in the AMK Products Guide to Ford Fasteners, nor in either Ford Standard and Utility Parts Catalogs, and no photo or drawing for this type of stud is shown. The dimensions I have are 7/16-14X1/2, 3/8-16X3/4, 1 5/8 oa length.
From what I've determined, the stud may or may not have been used on the 170CID I-6, all that is shown is an existing stud (see E4-8125-1, 64 Electrical Manual) for the battery ground, with or without an AT.
For 65 thru 68 200CID I-6 engines with automatic transmissions, it was used per Illustration Section A71, page 6.
For 66 thru 68 289CID V-8 engines with automatic transmissions, it was used per Illustration Section A71, page 6. It was not used in 1965 on 289CID V-8 engines with AT's, at least on my May build San Jose or on a January San Jose build.
This stud is different from 380818-S in that it is threaded 7/16-14 on each end which is what I've found on my two 66 Mustangs and a couple of others with 289CID V-8 engines. The V-8 battery cable has a 7/16 dia lug.
I have a couple of the 7/16-14 - 3/8-16 I-6 studs (the one shown, thanks Dave) available already clear zinc plated with the appropriate two washers and nut. Send me a p/m if you are interested.
Offline Pete Bush
« Reply #11 on: June 10, 2012, 05:23:25 PM »
Here's a picture of the bolt and bracket I picked up on Ebay two weeks ago. It was advertised as a "transmission line bracket support grounding".
Offline GarlicGreg
« Reply #12 on: June 10, 2012, 06:13:40 PM »
Just finishing my '65 San Jose coupe. Here is what I found. Negative cable went straight to stud on the top of a head bolt. Alternator ground went to block with the clip for the trans cooling lines. Just found my clip so I will put that on this afternoon. Here are some good pics of all. Hope this helps.
« Reply #13 on: June 10, 2012, 08:56:08 PM »
It looks like the 200CID I-6 in 1965 used a 3/8-16 stud on, near or part of the RH front head bolt (again, not well defined) per E5-8126-1. There is no listing in the I-6 engine section (Sec 60.2 pg 6, part group 6065) for a special head bolt with a stud so apparently it was not serviced. A dealer "fix" required the ground cable to be hooked up to the 3/8-16 bolt/stud on the RH side of the block which was the 66 and on method.
(I'm glad I had only V-8 Mustangs - not gloat, just glad.)
Offline sparky65
« Reply #14 on: June 11, 2012, 07:11:36 PM »
Jim, I sent you a PM.
What about the clip, seems I recall seeing that reproduced somewhere or am I imagining things?
I thought restoring a I6 was going to be easier then a V8 but I am finding out there are a lot of difficult to find pieces.  I saw on another forum that Scott Drake may be reproducing the valve cover clip so maybe some pieces will be easier to find.
Steve
2009 Black GT Coupe
