Author Topic: 1970 Metuchen Mach1 all original car. looking for build sheet.  (Read 693 times)
Offline keeper
We have pulled the front and back seats out, lifted the carpet exposing all original sound deadener and no luck finding the build sheet. Not under the seats between the retention springs and burlap liner either. Any tips would be greatly appreciated. Thanks in advance. Keeper
Keith 69 Mach1TopLoader/Vcode SJ
Re: 1970 Metuchen Mach1 all original car. looking for build sheet.
« Reply #1 on: May 30, 2023, 05:31:09 PM »
For that plant try the main dash wire loom behind the gauge cluster Since you have already checked between the carpet underlayment and the floor (one I've seen the most often - that year and plant) and between the seat springs.  One Dearbornssoem have been found on backside of the door panels. Might as well check there also.
Offline keeper
« Reply #2 on: May 30, 2023, 05:36:17 PM »
Jeff, thank you for the help. I will pass this on sir.
