Author Topic: 5/16 fuel line spring clamp with square corners  (Read 2475 times)
Offline S412gofast
« on: May 22, 2023, 10:56:12 AM »
I have been searching and purchasing various constant tension spring clamps to find one suitable for the fuel line hose on our 1967 Shelby GT350.
I tried AMK ...no luck,  and the 3/8 clamps from NPD are great but for 3/8 application.
I tried local Autozone and Napa.
*Corrected Autozone description and link*
Autozone
Description: Dorman - HELP Quick Connector 3/8in, 1/2in, 9/16in, 5/8in Hose Clamp Assortment 8 Piece
https://www.autozone.com/gaskets-and-miscellaneous-fasteners/hose-clamp/p/dorman-help-quick-connector-3-8in-1-2in-9-16in-5-8in-hose-clamp-assortment-8-piece/730002_0_0?spps.s=3209&cmpid=LIA:US:EN:AD:NL:1000000:HRD:19489353553&&CATARGETID=120054150001290089&CADevice=m&gclid=EAIaIQobChMIwbvdmK-K_wIVvuzjBx2MWAZvEAQYASABEgJ4ePD_BwE&gclsrc=aw.ds
This kit contained 2 clamps (1/2) suitable for 5/16 fuel hose application.  These clamps feature long rounded tangs which allows you to square them off and still have long tangs.  These clamps had to be modified as follows to have the appearance of the clamps that were originally used by using a dremel with a cutoff wheel.  Yellow lines denote modified features.
1. Square off 3 tangs
2. Along the bands circumference the wide part transitions to the narrow part with a 90 degree feature vs an angle as in the originals.  I used the dremel to change 90 to angle.
3. Painted clamps olive drab
Napa also had constant tension clamps
Description: Hose Clamps, Fits 1/2" OD hose
https://www.napaonline.com/en/p/SME7019502
These clamps pictured below actually had a briggs and stratton designation on the packaging.
The Napa clamp had the shorter length rounded tangs, of which were still usable when the tangs were squared off slightly, however resulting in a much shorter tang then the Dorman clamps.
« Last Edit: May 23, 2023, 06:39:59 AM by S412gofast »
1967 GT350 01341, FORD Build: 2/28/67 ; SAI Build 3/28/67
1966 GT 2+2, 4spd, PS, tinted windows, Raven Black w/Black Pony interior; FORD Build: 10/11/65
1986 SVO, Oxford White w/Leather interior
1987 Saleen #132 Dark Gray Metallic
Re: 5/16 fuel line spring clamp with square corners
« Reply #1 on: May 22, 2023, 04:10:14 PM »
Very good job and the DIY will be very helpful to those wanting the historical look. FYI at least some of the 5/16 square ear clamps from the era that found their way onto the cars were dark steel instead of olive drab. At least some of the assembly line clamps used had the diamond makers mark on the band. Not meant to diminish your effort but in the hopes of helping get things better I would point out in a helpful way that the fuel filter has the later or aftermarket thin hex base compare to the thicker or taller one that came on the cars . Also from the picture the fuel line appears to be stainless steel or some modern shiny steel equivalent instead of the Terne Steel treated lines like assemblyline.
« Reply #2 on: May 22, 2023, 07:16:11 PM »
Nice job on the finish. Thanks for sharing
As for the Diamond/U marking here are a few examples
And for others seeing the thread the finish change after 67 for most of these as used on our cars
« Reply #3 on: May 22, 2023, 07:46:30 PM »
Autozone
Description: Dorman - Help Hose Clamp 16 pack 90099.
https://www.autozone.com/collision-body-parts-and-hardware/fuel-hose-clamp/p/dorman-help-hose-clamp-16-pack-90099/347151_0_0
I went to auto zone to check out the clamps and that number (Description: Dorman - Help Hose Clamp 16 pack 90099.)corresponds to a much smaller tiny clamp. Confirmed same 90099 number on the blister pack. I showed the clerk the auto zone online image from your link and he double checked and confirmed that number corresponded to the much smaller clamps. I went to Advance Auto and the same thing with small clamps in the help section .
Offline S412gofast
« Reply #4 on: May 22, 2023, 11:09:51 PM »
Bob
Autozone Description and link has been corrected.
I will circle back with a picture of the package I bought off the rack in the store.
Also to address your mentions, filter is a motorcraft from NPD (just found an orig Autolite C5AE-9155-A4, need to install) and yes fuel line is stainless.
Carl
« Last Edit: May 23, 2023, 07:04:53 AM by S412gofast »
Offline S412gofast
« Reply #5 on: June 26, 2023, 10:47:00 AM »
Bob
Carl
Forgot about adding pic of package.  All tension clamps in this set have very long tangs that can easily be squared off.
« Reply #6 on: June 26, 2023, 09:07:25 PM »
Thanks for helping others. To help them make choices other than they don't have the original markings what is the finish on these replacements?
Offline S412gofast
« Reply #7 on: June 27, 2023, 09:28:40 AM »
Thats what we are here for!
The finish our of the package is a black spring steel finish.  After modifiying the clamp as noted in this thread I painted them the drab olive green.
As Bob G. noted above some of the 5/16 clamps were the dark spring steel as these seem to be out of the box.  You could modify these as noted in orig post with a dremel then apply Perma-Blue to the modified edges.
« Last Edit: June 27, 2023, 09:33:50 AM by S412gofast »
« Reply #8 on: June 27, 2023, 03:37:59 PM »
Since I was aware of what you were working on my comment about the dark manganese phosphate finish vs olive drab was in the context of 67 Shelby at the filter only. I do no have any relevant commentary that is different then olive drab on a regular 67 Mustang.
